MAC OS 10.6.8 Won't Install
Help for Audacity on macOS.
smarout
Re: MAC OS 10.6.8 Won't Install
Post by smarout » Tue Apr 30, 2013 12:57 am
Ok so I did what gale said, but now it says it cant find the nyquist and i cant use them. Suggestions?
Post by Gale Andrews » Tue Apr 30, 2013 1:39 am
smarout wrote:Ok so I did what gale said, but now it says it cant find the nyquist
Ensure you have installed Audacity properly. You need to drag the "Audacity" folder from the DMG into /Applications, then run Audacity.app from /Applications.
Don't copy the DMG to /Applications. Don't run Audacity from the DMG.
Does that help?
If not, are you running a case-sensitive file system ?
