Correcting wrong recording length
Help for Audacity on macOS.
wellhellokitty289
Post by wellhellokitty289 » Sun Apr 28, 2013 2:31 pm
Hi, new to the forum. I really need someone's help ASAP! I was able to slow down the background noise on a recording, however, the conversation itself I could not slow down. Can someone please assist me with this. :cry:
Last edited by wellhellokitty289 on Fri Apr 24, 2015 4:16 pm, edited 2 times in total.
Reason: Topic split
Re: Correcting wrong recording length
Post by steve » Sun Apr 28, 2013 2:56 pm
If you have a question, please start a new topic rather than adding you question to the end of an old topic (particularly as the topic that you posted to was marked "solved", so you are very lucky to get a reply at all).
wellhellokitty289 wrote: I was able to slow down the background noise on a recording,
How did you do that?
Why did you do that?
Are you using a Mac computer?
What are you trying to do?
