Problem changing pitch
Help for Audacity on macOS.
maximlee
Post by maximlee » Sun Apr 21, 2013 1:15 pm
i want to change the pitch of song from 440 to 432... when i go to effects/change pitch it wont allow me to type into the frequency box from provided. I have searched forum but this is not covered.... does anyone have any idea why this could be the case? if i have explained correctly or in any way unsure what im on about watch from 7.25min on this video http://www.youtube.com/watch?v=qWSxERh9N-I
many thanks
maximlee
Robert J. H.
Re: Problem changing pitch
Post by Robert J. H. » Sun Apr 21, 2013 4:21 pm
You can try a half step value of
-0.317667
maximlee
Post by maximlee » Tue Apr 23, 2013 10:25 pm
thanks for reply... would rather find out why its not working but if they are both the same then i guess its ok. will give it a shot :O)
Post by steve » Tue Apr 23, 2013 11:12 pm
maximlee wrote:when i go to effects/change pitch it wont allow me to type into the frequency box from provided. I have searched forum but this is not covered
It gets a brief mention in the manual:
If changing by pitch, modify the "To:" and optionally the "From:". If modifying by frequency, modify only the "to".
(emphasis mine).
In the current version of "Change Pitch", the "From: Frequency" is not intended to be editable, even though it looks like it should be.
I'm somewhat surprised that the video shows it to be editable, but I notice that he is using an old version of Audacity, The fact that it worked in an older version strengthens the case for why it should work now.
I am currently working on a new version of "Change Pitch" in which the "From: frequency" can be edited. I am not an official Audacity developer so there is no guarantee that my proposal will be accepted, but if you would like to see this change in a future version of Audacity I suggest that you request it in the "Adding Features" section of the forum. http://forum.audacityteam.org/viewforum.php?f=20 (the developers are more likely to accept a new feature if users say that they want it).
