'Cut' button doesn't work and 'Cut' in Edit is missing
Help for Audacity on macOS.
Malcolm GC
Post by Malcolm GC » Sun Apr 14, 2013 10:27 pm
After highlighting a section of the wave form, I can't cut or delete it, because the Cut button has no effect and Cut is absent from the Edit menu.
I am using MAc OS X 10.7.5. What's wrong?!
Malcolm GC
Re: 'Cut' button doesn't work and 'Cut' in Edit is missing
Post by steve » Sun Apr 14, 2013 10:37 pm
The Cut menu option is in "Edit menu > Remove Audio or Labels > Cut" http://manual.audacityteam.org/o/man/edit_menu.html#cut
Note that playback must be stopped (not playing, recording or paused).
Bari
Post by Bari » Mon Apr 22, 2013 4:49 am
I am having the same problem. I have highlighted the clip I want to use and saved it as an Audacity file on my desktop. I can open it from there using Audacity, and only the edited clip plays. But I can't cut the unwanted part off as the scissors and the "cut" option under "remove audio labels" are both greyed out.
I saved it as a WAV file using the import button as suggested, but it saved the entire track, not just the selected clip. I need to know how to save just the selected clip in a format I can email. Can anyone help?
Post by steve » Mon Apr 22, 2013 9:45 am
Bari wrote:I can't cut the unwanted part off as the scissors and the "cut" option under "remove audio labels" are both greyed out.
Playback must be stopped (not playing, recording or paused).
Bari wrote:I saved it as a WAV file using the import button as suggested
I don't think anyone suggested that.
"Import" does not save files, it "reads" files (imports them into the current project).
Bari wrote:I need to know how to save just the selected clip in a format I can email.
File menu > Export Selection.
Note that for MP3 export you will need to install LAME: http://manual.audacityteam.org/o/man/fa ... .html#lame
For WMA and some of the other fancy formats you will need to install FFMpeg: http://manual.audacityteam.org/o/man/fa ... tml#ffdown
For exporting in WAV, OGG, FLAC, AIFF formats you don't need to install any additional software as these are open formats supported natively by Audacity.
Bari
Post by Bari » Sun Apr 28, 2013 2:01 am
Thank you. The downloads seem to have fixed it.
billw58
Post by billw58 » Sun Apr 28, 2013 4:47 pm
Bari wrote:Thank you. The downloads seem to have fixed it.
What downloads?
-- Bill
