Audacity for Mac not full installing[SOLVED]
Help for Audacity on macOS.
wondercast
Post by wondercast » Thu Apr 11, 2013 4:08 pm
I don't know if anyone has come across this problem, but it seems after installing Audacity for Mac on my mac, and then eject the installer, I close audacity and then try to open it again, Audacity will not open and I have to install the program again. Is anyone else familiar with problem?
Re: Audacity for Mac not full installing
Post by steve » Thu Apr 11, 2013 4:11 pm
It sounds like you are running Audacity directly from the dmg and are not fully installing it. Please check the installation instructions here: http://audacityteam.org/download/mac
wondercast
Re: Audacity for Mac not full installing[SOLVED]
Post by wondercast » Fri Apr 12, 2013 2:48 am
ok. It works now.
