transfering settings from one project to another
Help for Audacity on macOS.
johnythehess
Post by johnythehess » Fri Mar 29, 2013 8:32 pm
Good afternoon. I am using Lion with the latest version of Audacity from the DMG file. I have created EQ presets and would like to be able to migrate them to different projects. Example: I am working on a project for church where I am mixing the music from the different services. Rather than having to import the files and then apply the EQ to each track using the presets I saved is there a way to save a blank project with the eqs already applied to the tracks so that when I import the files they will assume the settings of each track? I'm just looking for a way to streamline the process of always having to apply the EQ each time I create a new project. The tracks are usually the same in each, kick, snare, tom and so on. Thanks.
Re: transfering settings from one project to another
Post by Gale Andrews » Sat Mar 30, 2013 5:13 am
You could add Equalization (configured to use your preset) to a "Chain", import the files then apply the Chain to the current project ( http://manual.audacityteam.org/o/man/ba ... ssing.html ).
