No sound after exporting
meindersma
I have exported several files in both WAV and AIFF format, but I cannot play them with iTunes, only with Audacity. How can I get a sound or burn a cd?
waxcylinder
Re: No sound after exporting
see this tutorial in the manual: http://manual.audacityteam.org/o/man/bu ... _a_cd.html
this one may be useful to you too: http://manual.audacityteam.org/o/man/sp ... racks.html
- Quality Assurance
If the time counter moves in iTunes but you cannot hear the audio, open System Preferences > Sound and make sure the playback device is set to the device you have your speakers or headphones connected to.meindersma wrote:I have exported several files in both WAV and AIFF format, but I cannot play them with iTunes, only with Audacity. How can I get a sound or burn a cd?
If you don't have external speakers or headphones, just choose the built-in playback device.
