Audacity crashes on launch Mac OSX 10.8.2[SOLVED]
Help for Audacity on macOS.
Sixpack5001
Post by Sixpack5001 » Fri Feb 15, 2013 7:19 am
Hi all,
I'm on a MacBook Pro Retina running OSX 10.8.2 on a 2.7 GHz i7 processor with 16gb RAM, and I have the latest version of Audacity, as I downloaded it last week.
Whenever I open Audacity, it brings up a warning window which says "Wallander Instruments - Can't create WIVI's Application Support folder - Location: /Library/Application Support/WIVI." This happens sometimes in Ableton Live without any consequence, so I don't think anything of it. But after I click OK, nothing happens, and Audacity soon "encounters a problem and needs to close.
I've tried the Audacity.cfg fix in Application Support, but to no avail. Anyone have any idea what I could do?
Crash report here: https://docs.google.com/document/d/1eea ... rLC6aA/pub
Thanks in advance. :D
Re: Audacity crashes on launch Mac OSX 10.8.2
Post by kozikowski » Fri Feb 15, 2013 7:51 am
The obvious question is: "What's Wallander Instruments?"
I don't have one of those. I spotlighted and straight searched. Zip.
If it has anything to do with the sound services, you may have to disable it. Audacity is pretty simple and doesn't like sharing it's resources with others.
Post by Gale Andrews » Fri Feb 15, 2013 7:29 pm
Waves V8 Audio Units shown in the crashed thread are known to be incompatible with Audacity.
So you will have to move Waves where Audacity cannot find it, or disable Audio Unit support in Audacity by editing audacity.cfg. Did you make sure you force quit Audacity before editing audacity.cfg? See here for full instructions:
http://wiki.audacityteam.org/wiki/User: ... ces_on_Mac .
The VST version of the "sausagefattener" should not be in /Library/Application Support/ . It should be installed in one of /Users/<user>/Library/Audio/Plug-Ins/VST or /Library/Audio/Plug-Ins/VST . That may be the cause of the error. Audacity should hopefully ignore it (it does not support VST synths). If Audacity still crashes after disabling Audio Unit support in audacity.cfg, try uninstalling the sausagefattener (or disabling VST support in audacity.cfg as well as Audio Unit support).
calmcent
Post by calmcent » Fri Jul 12, 2013 7:45 am
I'm having same problem - just started - can't figure out why.
Mac OSX 10.8.4 (Air, 8g ram)
Code: Select all
Process:         Audacity [980]
Path:            /Applications/Audacity/Audacity.app/Contents/MacOS/Audacity
Identifier:      net.sourceforge.audacity
Version:         2.0.4.0 (2.0.4.0)
Code Type:       X86 (Native)
Parent Process:  sh [977]
User ID:         502
Date/Time:       2013-07-12 17:32:44.171 +1000
OS Version:      Mac OS X 10.8.4 (12E55)
Report Version:  10
Interval Since Last Report:          96313 sec
Crashes Since Last Report:           11
Per-App Interval Since Last Report:  10 sec
Per-App Crashes Since Last Report:   3
Anonymous UUID:                      903F05EE-FFE1-E23C-26EB-397E2AA675D8
Crashed Thread:  6
Exception Type:  EXC_BAD_ACCESS (SIGBUS)
Exception Codes: KERN_PROTECTION_FAILURE at 0x0000000000000034
VM Regions Near 0x34:
--> __PAGEZERO             0000000000000000-0000000000001000 [    4K] ---/--- SM=NUL  /Applications/Audacity/Audacity.app/Contents/MacOS/Audacity
    __TEXT                 0000000000001000-0000000000ab2000 [ 10.7M] r-x/rwx SM=COW  /Applications/Audacity/Audacity.app/Contents/MacOS/Audacity
Thread 0:: Dispatch queue: com.apple.main-thread
0   libsystem_kernel.dylib        	0x97f8a7d2 mach_msg_trap + 10
1   libsystem_kernel.dylib        	0x97f89cb0 mach_msg + 68
2   com.apple.CoreFoundation      	0x97509f79 __CFRunLoopServiceMachPort + 185
3   com.apple.CoreFoundation      	0x9750f95f __CFRunLoopRun + 1247
4   com.apple.CoreFoundation      	0x9750f01a CFRunLoopRunSpecific + 378
5   com.apple.CoreFoundation      	0x9750ee8b CFRunLoopRunInMode + 123
6   com.apple.HIToolbox           	0x91f48f5a RunCurrentEventLoopInMode + 242
7   com.apple.HIToolbox           	0x91f48cc9 ReceiveNextEventCommon + 374
8   com.apple.HIToolbox           	0x920ae15c ReceiveNextEvent + 79
9   Audacity                      	0x003e1b8b wxApp::MacDoOneEvent() + 91
10  Audacity                      	0x003fa4d3 wxEventLoop::Dispatch() + 35
11  Audacity                      	0x0048d10f wxEventLoopManual::Run() + 111
12  Audacity                      	0x00467353 wxAppBase::MainLoop() + 83
13  Audacity                      	0x00547dca wxEntry(int&, wchar_t**) + 154
14  Audacity                      	0x0003f118 main + 24
15  Audacity                      	0x0003eebe _start + 216
16  Audacity                      	0x0003ede5 start + 41
Thread 1:: Dispatch queue: com.apple.libdispatch-manager
0   libsystem_kernel.dylib        	0x97f8d9ae kevent + 10
1   libdispatch.dylib             	0x94d72c71 _dispatch_mgr_invoke + 993
2   libdispatch.dylib             	0x94d727a9 _dispatch_mgr_thread + 53
Thread 2:
0   libsystem_kernel.dylib        	0x97f8d0ee __workq_kernreturn + 10
1   libsystem_c.dylib             	0x95b3a0ac _pthread_workq_return + 45
2   libsystem_c.dylib             	0x95b39e79 _pthread_wqthread + 448
3   libsystem_c.dylib             	0x95b21d2a start_wqthread + 30
Thread 3:
Thread 4:
Thread 5:
0   libsystem_kernel.dylib        	0x97f8a8e6 mach_wait_until + 10
1   libsystem_c.dylib             	0x95bc8c10 nanosleep + 375
2   Audacity                      	0x000501a4 AudioThread::Entry() + 100
3   libsystem_c.dylib             	0x95b375b7 _pthread_start + 344
4   libsystem_c.dylib             	0x95b21d4e thread_start + 34
Thread 6 Crashed:
0   com.digitech.au.rp350         	0x0b0926a0 XParamRP::SetMapArray_ForLinks(unsigned long*, unsigned long) + 18
1   com.digitech.au.rp350         	0x0b08a253 XDeviceLibRP::SetNewModListFlag(bool) + 69
2   com.digitech.au.rp350         	0x0b08c2f2 XDeviceMsgRP::ProcessRecieveModifierList(hmg::CSuper7RxSysexMsg*) + 198
3   com.digitech.au.rp350         	0x0b08be4c XDeviceMsgRP::ProcessNewMessage(hmg::CSuper7RxSysexMsg*) + 972
4   com.digitech.au.rp350         	0x0b08edbc XDeviceMsgBase::ProcessMIDIPacket(MIDIPacket*) + 406
5   com.digitech.au.rp350         	0x0b08d565 XMidiPortRP::ProcessMIDIPacket(MIDIPacket*) + 81
6   com.digitech.au.rp350         	0x0b08d598 MyMIDIReadProc(MIDIPacketList const*, void*, void*) + 48
7   com.apple.audio.midi.CoreMIDI 	0x012a524f LocalMIDIReceiver::HandleMIDIIn(MIDIPacketList const*, OpaqueMIDIEndpoint*, void*) + 57
8   com.apple.audio.midi.CoreMIDI 	0x012a3ac9 LocalMIDIReceiverList::HandleMIDIIn(void*, OpaqueMIDIEndpoint*, void*, MIDIPacketList const*) + 91
9   com.apple.audio.midi.CoreMIDI 	0x0129eb5b MIDIProcess::RunMIDIInThread() + 267
10  com.apple.audio.midi.CoreMIDI 	0x012a4c48 MIDIProcess::MIDIInPortThread::Run() + 24
11  com.apple.audio.midi.CoreMIDI 	0x01282805 XThread::RunHelper(void*) + 17
12  com.apple.audio.midi.CoreMIDI 	0x012822ee CAPThread::Entry(CAPThread*) + 196
13  libsystem_c.dylib             	0x95b375b7 _pthread_start + 344
14  libsystem_c.dylib             	0x95b21d4e thread_start + 34
Thread 7:
0   libsystem_kernel.dylib        	0x97f8c8e2 __psynch_cvwait + 10
1   libsystem_c.dylib             	0x95b3c2e9 _pthread_cond_wait + 938
2   libsystem_c.dylib             	0x95b3c572 pthread_cond_timedwait_relative_np + 47
3   com.apple.audio.midi.CoreMIDI 	0x012816e7 CAGuard::WaitFor(unsigned long long) + 229
4   com.apple.audio.midi.CoreMIDI 	0x012817ff CAGuard::WaitUntil(unsigned long long) + 205
5   com.apple.audio.midi.CoreMIDI 	0x01282748 Task::Run() + 330
6   com.apple.audio.midi.CoreMIDI 	0x01282805 XThread::RunHelper(void*) + 17
7   com.apple.audio.midi.CoreMIDI 	0x012822ee CAPThread::Entry(CAPThread*) + 196
8   libsystem_c.dylib             	0x95b375b7 _pthread_start + 344
9   libsystem_c.dylib             	0x95b21d4e thread_start + 34
Thread 6 crashed with X86 Thread State (32-bit):
  eax: 0x0b1cf004  ebx: 0x0b08a220  ecx: 0x0b1cf004  edx: 0x00000000
  edi: 0x00000025  esi: 0x0b1cf000  ebp: 0xb0309d28  esp: 0xb0309d20
   ss: 0x00000023  efl: 0x00010282  eip: 0x0b0926a0   cs: 0x0000001b
   ds: 0x00000023   es: 0x00000023   fs: 0x00000023   gs: 0x0000000f
  cr2: 0x00000034
Logical CPU: 3
Binary Images:
    0x1000 -   0xab1fe7 +Audacity (???) <D7DADAF5-B08E-C772-24C7-98D5553F8942> /Applications/Audacity/Audacity.app/Contents/MacOS/Audacity
 0x10a3000 -  0x11c2ffb  com.apple.WebKit (8536 - 8536.30.1) <4A5E9136-681F-3AB1-AD69-B59F2B9126E7> /System/Library/Frameworks/WebKit.framework/Versions/A/WebKit
 0x1273000 -  0x12bbffb  com.apple.audio.midi.CoreMIDI (1.9 - 78) <7AAE4076-36FA-37C1-9EAE-344F1C8F14D9> /System/Library/Frameworks/CoreMIDI.framework/Versions/A/CoreMIDI
 0x12e0000 -  0x1f75ff3  com.apple.WebCore (8536 - 8536.30.2) <D644997F-5F1A-34B4-AF32-DD427E9043E2> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versions/A/WebCore
 0x26fa000 -  0x2710ffc  libexpat.1.dylib (12) <D4F1FD2B-F75A-322C-843E-113EF5F8EEAF> /usr/lib/libexpat.1.dylib
 0x2792000 -  0x2793ffd  com.apple.textencoding.unicode (2.5 - 2.5) <4E2ABBEB-1F0D-3C06-BA0C-C3CEDDF17BD2> /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
 0x27ae000 -  0x27b2fff  com.apple.CommonCocoaPanels (4.0 - 16) <7676B15F-69E2-39D2-9F35-9D2959A99079> /System/Library/CoreServices/CommonCocoaPanels.bundle/Contents/MacOS/CommonCocoaPanels
 0x2b00000 -  0x2bbeff3  ColorSyncDeprecated.dylib (400) <35E3054C-5DF1-30D4-A368-C4FDB0992373> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/Resources/ColorSyncDeprecated.dylib
 0x2cb0000 -  0x2cbdff3  com.apple.Librarian (1.1 - 1) <68F8F983-5F16-3BA5-BDA7-1A5451CC02BB> /System/Library/PrivateFrameworks/Librarian.framework/Versions/A/Librarian
 0x2f79000 -  0x2f7affd  com.apple.ironwoodcore (1.1.1 - 1.1.1) <098CE576-3239-3B41-9141-A5BE6E476C84> /System/Library/PrivateFrameworks/SpeechObjects.framework/Versions/A/Frameworks/DictationServicesCore.framework/DictationServicesCore
 0x2fb8000 -  0x2fbbff7 +gverb_1216.so (???) <B8A3EF2E-B6BB-1B6C-DBE2-A06B4F7F066C> /Applications/Audacity/*/gverb_1216.so
 0x2fbf000 -  0x2fbfff7 +hard_limiter_1413.so (???) <DF93382E-6CFD-32EE-5FBA-1F428F821839> /Applications/Audacity/*/hard_limiter_1413.so
 0x2fc3000 -  0x2fc5ff7 +sc4_1882.so (???) <8EA4B893-DD1B-CFAB-42B4-65C3695A7869> /Applications/Audacity/*/sc4_1882.so
 0x46b9000 -  0x46befff  com.apple.audio.AppleHDAHALPlugIn (2.3.7 - 2.3.7fc4) <903097A8-3922-3BF8-8B82-8BD1D831F6E7> /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHALPlugIn.bundle/Contents/MacOS/AppleHDAHALPlugIn
 0x4799000 -  0x479cfef  com.apple.LiveType.component (2.1.3 - 2.1.3) /Library/QuickTime/LiveType.component/Contents/MacOS/LiveType
 0x47a1000 -  0x47e7fc3  com.apple.motion.component (1.0 - 1.0) <77973A13-4E79-426F-853F-2318E52A2207> /Library/QuickTime/Motion.component/Contents/MacOS/Motion
 0x47ed000 -  0x47f002f  Motion (1) <B5E862EE-E0FF-4F86-A789-98E3E601A18C> /Library/Frameworks/Motion.framework/Versions/A/Motion
 0x67fc000 -  0x6861fde  com.apple.LiveType.framework (2.1.3 - 2.1.3) /System/Library/PrivateFrameworks/LiveType.framework/Versions/A/LiveType
 0x6881000 -  0x68f3fff +com.DivXInc.DivXDecoder (6.4.0 - 6.4.0) /Library/QuickTime/DivX Decoder.component/Contents/MacOS/DivX Decoder
 0xa6dc000 -  0xa9cbfe3 +com.elgato.mpegsupport (EyeTV MPEG Support 1.3 [build 68] - 1.3) <C7563FAA-E5BF-6F9B-C1F4-3C6F538514F6> /Library/QuickTime/EyeTV MPEG Support.component/Contents/MacOS/EyeTV MPEG Support
 0xad88000 -  0xae36ffa +com.digitech.au.rp155 (1.0) <0F8F1F3B-1E4E-BC0E-3961-47076F606459> /Library/Audio/Plug-Ins/Components/RP155.component/Contents/MacOS/RP155
 0xaef3000 -  0xafa1ffa +com.digitech.au.rp255 (1.0) <82F15AE9-77CC-451D-011B-A67192887487> /Library/Audio/Plug-Ins/Components/RP255.component/Contents/MacOS/RP255
 0xb05e000 -  0xb10eff6 +com.digitech.au.rp350 (1.1) <1DC8789D-41D4-4CD7-BE1B-D30F6F51BFBD> /Library/Audio/Plug-Ins/Components/RP350.component/Contents/MacOS/RP350
 0xb275000 -  0xb32bfe6 +com.digitech.au.rp355 (1.0) <0D7CB3A2-C612-8FA4-175F-55FAA466F464> /Library/Audio/Plug-Ins/Components/RP355.component/Contents/MacOS/RP355
0x70000000 - 0x7015eff7  com.apple.audio.units.Components (1.9 - 1.9) <F2B2712A-3203-3875-B1FF-768E92AE0D42> /System/Library/Components/CoreAudio.component/Contents/MacOS/CoreAudio
0x8fe52000 - 0x8fe84e57  dyld (210.2.3) <4D38DEED-9837-3202-B8E9-41272D01EA2C> /usr/lib/dyld
0x907a9000 - 0x90921ff5  com.apple.QuartzCore (1.8 - 304.3) <F2EFC117-CDC6-3252-A4A8-880965764385> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x90922000 - 0x90b39fff  com.apple.CoreData (106.1 - 407.7) <EC4B8297-8E01-3778-A8A4-E8747F91109D> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x90b72000 - 0x90b7effa  com.apple.CrashReporterSupport (10.8.3 - 418) <03BC564E-35FE-384E-87D6-6E0C55DF16E3> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporterSupport
0x90b7f000 - 0x90b86ffe  com.apple.agl (3.2.1 - AGL-3.2.1) <B5A30D4D-F52B-3C3F-BA59-C22EABBDBD62> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
0x90bcf000 - 0x90cc7ff9  libsqlite3.dylib (138.1) <AD7C5914-35F0-37A3-9238-A29D2E26C755> /usr/lib/libsqlite3.dylib
0x90cc8000 - 0x90d60fff  com.apple.CoreServices.OSServices (557.6 - 557.6) <8DEEED08-A4B3-3B08-8C2A-BDDBF005B43F> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x90d61000 - 0x90e5fff7  libFontParser.dylib (84.6) <7D3EB3CC-527E-3A74-816A-59CAFD2260A4> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
0x911d9000 - 0x911e7fff  libxar.1.dylib (105) <343E4A3B-1D04-34A3-94C2-8C7C9A8F736B> /usr/lib/libxar.1.dylib
0x91225000 - 0x91234fff  libGL.dylib (8.9.2) <1082B9A5-9AA3-35D4-968B-3A3FE15B1ED7> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x91235000 - 0x91236ffd  com.apple.TrustEvaluationAgent (2.0 - 23) <E42347C0-2D3C-36A4-9200-757FFA61B388> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent
0x91237000 - 0x91245ff7  libz.1.dylib (43) <245F1B61-2276-3BBB-9891-99934116D833> /usr/lib/libz.1.dylib
0x912e4000 - 0x91ea0ff3  com.apple.AppKit (6.8 - 1187.39) <ACA24416-D910-39B8-9387-52A6C6A561F8> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x91ea1000 - 0x91eadff7  com.apple.NetAuth (4.0 - 4.0) <4983C4B8-9D95-3C4D-897E-07743326487E> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
0x91ef1000 - 0x922d4fff  com.apple.HIToolbox (2.0 - 626.1) <ECC3F04F-C4B7-35BF-B10E-183B749DAB92> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x92331000 - 0x92356ff7  com.apple.CoreVideo (1.8 - 99.4) <A26DE896-32E0-3D5E-BA89-02AD23FA96B3> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x9242e000 - 0x92517ff7  libxml2.2.dylib (22.3) <015A4FA6-5BB9-3F95-AFB8-B9281E22685B> /usr/lib/libxml2.2.dylib
0x92518000 - 0x92524ffe  libkxld.dylib (2050.24.15) <BEC097B0-9D9A-3484-99DB-0F537E71963E> /usr/lib/system/libkxld.dylib
0x92525000 - 0x92616ffc  libiconv.2.dylib (34) <B096A9B7-83A6-31B3-8D2F-87D91910BF4C> /usr/lib/libiconv.2.dylib
0x92617000 - 0x92679fff  libc++.1.dylib (65.1) <C0CFF9FF-5D52-3EAE-B921-6AE1DA00A135> /usr/lib/libc++.1.dylib
0x9267a000 - 0x9267dff9  libCGXType.A.dylib (332) <07B59FCC-6229-37C2-9870-70A18E2C5598> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGXType.A.dylib
0x9267e000 - 0x9278b057  libobjc.A.dylib (532.2) <FA455371-7395-3D58-A89B-D1520612D1BC> /usr/lib/libobjc.A.dylib
0x927b8000 - 0x927b8fff  com.apple.CoreServices (57 - 57) <956C6C6D-A5DD-314F-9C57-4A61D41F30CE> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x927b9000 - 0x927e2fff  libxslt.1.dylib (11.3) <0DE17DAA-66FF-3195-AADB-347BEB5E2EFA> /usr/lib/libxslt.1.dylib
0x92a7e000 - 0x92a7effd  libOpenScriptingUtil.dylib (148.3) <87895E27-88E2-3249-8D0E-B17E76FB00C1> /usr/lib/libOpenScriptingUtil.dylib
0x92a7f000 - 0x92a8bff8  libbz2.1.0.dylib (29) <7031A4C0-784A-3EAA-93DF-EA1F26CC9264> /usr/lib/libbz2.1.0.dylib
0x92a8c000 - 0x92a8fff7  libcompiler_rt.dylib (30) <CE5DBDB4-0124-3E2B-9105-989DF98DD108> /usr/lib/system/libcompiler_rt.dylib
0x92a90000 - 0x92a91fff  libDiagnosticMessagesClient.dylib (8) <39B3D25A-148A-3936-B800-0D393A00E64F> /usr/lib/libDiagnosticMessagesClient.dylib
0x92a92000 - 0x92af3fff  com.apple.audio.CoreAudio (4.1.1 - 4.1.1) <A3B911DB-77DF-3037-A47A-634B08E5727D> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x92af4000 - 0x92b63ffb  com.apple.Heimdal (3.0 - 2.0) <964D9952-B0F2-34F6-8265-1823C0D5EAB8> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
0x92b64000 - 0x92b91ffe  libsystem_m.dylib (3022.6) <9975D9C3-3B71-38E3-AA21-C5C5F9D9C431> /usr/lib/system/libsystem_m.dylib
0x92e7f000 - 0x92e81fff  libdyld.dylib (210.2.3) <05D6FF2A-F09B-309D-95F7-7AF10259C707> /usr/lib/system/libdyld.dylib
0x92e82000 - 0x92e9ffff  libxpc.dylib (140.43) <C628073D-51A0-3541-A665-1121520508C6> /usr/lib/system/libxpc.dylib
0x92ea3000 - 0x92eaaffb  libunwind.dylib (35.1) <E1E8D8B3-3C78-3AB1-B398-C180DC6DCF05> /usr/lib/system/libunwind.dylib
0x92eab000 - 0x92ec9ff3  com.apple.openscripting (1.3.6 - 148.3) <F3422C02-5ACB-343A-987B-A2D58EA2F5A8> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x92eca000 - 0x92f25fff  com.apple.htmlrendering (77 - 1.1.4) <5C0C669F-AE07-3983-B38F-EB829B5CE609> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework/Versions/A/HTMLRendering
0x92f6e000 - 0x935faff3  com.apple.CoreAUC (6.16.13 - 6.16.13) <3DCF4456-AF8D-3E87-B00C-C56055AF9B8E> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
0x935fb000 - 0x93628ffb  com.apple.CoreServicesInternal (154.3 - 154.3) <A452602B-67CB-39C4-95EB-E59433C65774> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesInternal
0x9363a000 - 0x9364aff2  com.apple.LangAnalysis (1.7.0 - 1.7.0) <875363E7-6D02-3229-A9DD-E5A5568A7D61> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x9364b000 - 0x9364fffc  libGIF.dylib (850) <45CD8B8F-7324-3187-B01C-8E16C04F33FA> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x93957000 - 0x9395efff  libsystem_dnssd.dylib (379.38.1) <4F164CA8-4A4F-3B27-B88A-0926E2FEB7D4> /usr/lib/system/libsystem_dnssd.dylib
0x93963000 - 0x93c68ff7  com.apple.CoreServices.CarbonCore (1037.6 - 1037.6) <4DB4B0C9-1377-3062-BE0E-CD3326ACDAF0> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x93c93000 - 0x93cedffb  com.apple.AE (645.6 - 645.6) <44556FF7-A869-399A-AEBB-F4E9263D9152> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x93cee000 - 0x93ceffff  libdnsinfo.dylib (453.19) <3B523729-84A8-3D0B-B58C-3FC185060E67> /usr/lib/system/libdnsinfo.dylib
0x93cf0000 - 0x93cf4fff  com.apple.OpenDirectory (10.8 - 151.10) <B9244697-CB05-3BD3-80A7-D188B3747B03> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
0x93cf5000 - 0x93d43ff3  com.apple.SystemConfiguration (1.12.2 - 1.12.2) <15B4EFFC-22D1-3517-BE8C-7947DAA24729> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x93d44000 - 0x93d57ff9  com.apple.MultitouchSupport.framework (235.29 - 235.29) <451701B6-03CE-3F26-9FF0-92D8DA1467EE> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
0x93fc6000 - 0x9437effa  libLAPACK.dylib (1073.4) <9A6E5EAD-F2F2-3D5C-B655-2B536DB477F2> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x9437f000 - 0x9439bfff  libPng.dylib (850) <26AD967A-D55E-3C5A-A643-D9953136DE58> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x943f0000 - 0x9480dfff  FaceCoreLight (2.4.1) <B12C8721-EFB3-30A2-9A1B-ABCDF5670764> /System/Library/PrivateFrameworks/FaceCoreLight.framework/Versions/A/FaceCoreLight
0x9480e000 - 0x9480efff  com.apple.vecLib (3.8 - vecLib 3.8) <83160DD1-5614-3E34-80EB-97041016EF1F> /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
0x9480f000 - 0x94818ffd  com.apple.audio.SoundManager (4.0 - 4.0) <ABC5FE40-B222-36EB-9905-5C8C4BFD8C87> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/Versions/A/CarbonSound
0x94819000 - 0x9481afff  libquarantine.dylib (52.1) <094A1501-373E-3397-B632-8F7C5AC8EFD5> /usr/lib/system/libquarantine.dylib
0x9481b000 - 0x9483aff3  com.apple.Ubiquity (1.2 - 243.15) <E10A2937-D671-3D14-AF8D-BA25E601F458> /System/Library/PrivateFrameworks/Ubiquity.framework/Versions/A/Ubiquity
0x948d9000 - 0x94927ffb  libFontRegistry.dylib (100) <3B8350C2-4D8F-38C4-A22E-2F855D7E83D1> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
0x94928000 - 0x9494cfff  com.apple.PerformanceAnalysis (1.16 - 16) <1F963AEF-27CF-3FEB-BE9C-4C15AFE56DEA> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis
0x9494d000 - 0x94ba6ff5  com.apple.JavaScriptCore (8536 - 8536.30) <24A2ACA7-6E51-30C6-B9AE-17A77E511735> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
0x94ba7000 - 0x94bb2fff  libcommonCrypto.dylib (60027) <8EE30FA5-AA8D-3FA6-AB0F-05DA8B0425D9> /usr/lib/system/libcommonCrypto.dylib
0x94c11000 - 0x94c11ffd  com.apple.audio.units.AudioUnit (1.9 - 1.9) <F7638E43-F885-372E-9DAE-24D0C21AA66E> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x94c12000 - 0x94c4dfef  libGLImage.dylib (8.9.2) <9D41F71E-E927-3767-A856-55480E20E9D9> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x94c4e000 - 0x94c92ff7  libGLU.dylib (8.9.2) <F33F6C73-7F89-3B5B-A50F-2AB57BBA314D> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x94c93000 - 0x94ca1fff  com.apple.opengl (1.8.9 - 1.8.9) <1872D2CD-00A8-30D1-8ECC-B663F4E4C530> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x94ca2000 - 0x94cd7fff  libTrueTypeScaler.dylib (84.6) <B7DB746B-7A61-38EF-8CA7-408ED9C14A02> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libTrueTypeScaler.dylib
0x94cd8000 - 0x94d52ff7  com.apple.securityfoundation (6.0 - 55115.4) <69D92A90-971C-3CD3-BAB1-ADF958C568BC> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
0x94d58000 - 0x94d6dfff  com.apple.speech.synthesis.framework (4.1.12 - 4.1.12) <DE68CEB5-4959-3652-83B8-D2B00D3B932D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x94d6e000 - 0x94d80ff7  libdispatch.dylib (228.23) <86EF7D45-2D97-3465-A449-95038AE5DABA> /usr/lib/system/libdispatch.dylib
0x94d81000 - 0x94e2bfff  com.apple.LaunchServices (539.9 - 539.9) <C0E0CFFF-3714-3467-87DA-4A6F0AF1953B> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x94e2c000 - 0x94e78fff  libcorecrypto.dylib (106.2) <20EBADBA-D6D6-36F0-AE80-168E9AF13DB6> /usr/lib/system/libcorecrypto.dylib
0x94e79000 - 0x94f84ff7  libJP2.dylib (850) <3FFCEFA6-317A-34AF-8D99-AEBB017543C5> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
0x9509e000 - 0x950acff3  libsystem_network.dylib (77.10) <7FBF5A15-97BA-3721-943E-E77F0C40DBE1> /usr/lib/system/libsystem_network.dylib
0x950ad000 - 0x95181ff3  com.apple.backup.framework (1.4.3 - 1.4.3) <6EA22ED3-BA18-3A37-AE05-5D6FDA3F372F> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
0x95182000 - 0x9518fff7  com.apple.AppleFSCompression (49 - 1.0) <166AA1F8-E50A-3533-A3B5-8737C5118CC3> /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versions/A/AppleFSCompression
0x95190000 - 0x9523fff7  com.apple.CoreText (260.0 - 275.16) <873ADCD9-D361-3753-A220-CDD289196AD8> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
0x95240000 - 0x95240fff  libSystem.B.dylib (169.3) <D7C4320E-C2EA-3A09-A413-D1F78382050D> /usr/lib/libSystem.B.dylib
0x95241000 - 0x9525efff  libCRFSuite.dylib (33) <C9D72D0C-871A-39A2-8AFB-682D11AE7D0D> /usr/lib/libCRFSuite.dylib
0x9525f000 - 0x95502ff3  com.apple.CoreImage (8.4.0 - 1.0.1) <C25B9EEC-4824-3088-BC08-2EA516C0728C> /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks/CoreImage.framework/Versions/A/CoreImage
0x95503000 - 0x95520ff7  libresolv.9.dylib (51) <B9742A2A-DF15-3F6E-8FCE-778A58214B3A> /usr/lib/libresolv.9.dylib
0x9552b000 - 0x95535fff  com.apple.speech.recognition.framework (4.1.5 - 4.1.5) <B855E8B4-2EE3-3BFF-8547-98A0F084F9AF> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x95536000 - 0x95539fff  com.apple.help (1.3.2 - 42) <AD7EB1F0-A068-3A2C-9D59-38E59CEC0D96> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x9553e000 - 0x95557fff  com.apple.Kerberos (2.0 - 1) <9BDE8F4D-DBC3-34D1-852C-898D3655A611> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x95608000 - 0x95a4afff  com.apple.CoreGraphics (1.600.0 - 332) <67E70F21-A0F1-356F-90B7-4B90C468EE2C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x95a4b000 - 0x95a52ff3  com.apple.NetFS (5.0 - 4.0) <1F7041F2-4E97-368C-8F5D-24153D81BBDB> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
0x95a7f000 - 0x95aa3fff  libJPEG.dylib (850) <36FEAB05-86C5-33B9-9DE9-5FAD8AEBA15F> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x95aa4000 - 0x95b20ff3  com.apple.Metadata (10.7.0 - 707.11) <F9BB5BBE-69D0-3309-8280-2303EB1DC455> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x95b21000 - 0x95bdefeb  libsystem_c.dylib (825.26) <6E35A83F-1A5B-3AF9-8C6D-D7B57B25FB63> /usr/lib/system/libsystem_c.dylib
0x95bdf000 - 0x95c54ff7  com.apple.ApplicationServices.ATS (332 - 341.1) <BEE998BC-E4A5-3BA0-A6B5-31A1DFA1522C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x95c7b000 - 0x95dd4ffb  com.apple.audio.toolbox.AudioToolbox (1.9 - 1.9) <8BF022FC-C38A-34AA-8469-D98294094659> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x95dd5000 - 0x95ddffff  libCSync.A.dylib (332) <86C5C84F-11EC-39C0-9FAC-A93FDEEC3117> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCSync.A.dylib
0x95de0000 - 0x95de4ff7  libmacho.dylib (829) <5280A013-4F74-3F74-BE0C-7F612C49F1DC> /usr/lib/system/libmacho.dylib
0x95de5000 - 0x960a5ff3  com.apple.security (7.0 - 55179.13) <000FD8E9-D070-326A-B386-51314360FD5C> /System/Library/Frameworks/Security.framework/Versions/A/Security
0x960b4000 - 0x960f6ffb  com.apple.RemoteViewServices (2.0 - 80.6) <AE962502-4539-3893-A2EB-9D384652AEAC> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServices
0x964f4000 - 0x96520ff7  libsystem_info.dylib (406.17) <AA5611DB-A944-3072-B6BE-ACAB08689547> /usr/lib/system/libsystem_info.dylib
0x96521000 - 0x96578ff3  com.apple.HIServices (1.20 - 417) <B8410ABC-E0DB-31EB-B923-17F3B65B5F4C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x96579000 - 0x965a2ff7  libRIP.A.dylib (332) <521E60A6-A768-3CB8-B10D-D10EECD68A94> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
0x965d7000 - 0x96672fff  com.apple.CoreSymbolication (3.0 - 117) <2BBBE224-301D-3931-AEF2-DD967A6E9172> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication
0x966c3000 - 0x966e5fff  libc++abi.dylib (26) <3AAA8D55-F5F6-362B-BA3C-CCAF0D3C8E27> /usr/lib/libc++abi.dylib
0x966e6000 - 0x96762ffb  libType1Scaler.dylib (101.1) <0D94D786-29F7-33DB-B64B-B264FA5EACD2> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libType1Scaler.dylib
0x96763000 - 0x96767fff  com.apple.IOSurface (86.0.4 - 86.0.4) <6431ACB6-561B-314F-9A2A-FAC1578FCC86> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
0x96768000 - 0x96768fff  com.apple.Carbon (154 - 155) <17F1B675-E054-3D2C-900B-C9CE69F1FC31> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x96769000 - 0x9676affd  libunc.dylib (25) <58599CBF-E262-3CEA-AFE1-35560E0177DC> /usr/lib/system/libunc.dylib
0x9676b000 - 0x967fdffb  libvMisc.dylib (380.6) <6DA3A03F-20BE-300D-A664-B50A7B4E4B1A> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x96855000 - 0x96857ffb  libRadiance.dylib (850) <83434287-A09E-3A3F-A1AC-085B563BA46D> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x968a4000 - 0x968a6ffd  libCVMSPluginSupport.dylib (8.9.2) <D6D0BB75-42DA-3772-AB5E-CBD59B343393> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib
0x968a7000 - 0x96a30ff7  com.apple.vImage (6.0 - 6.0) <1D1F67FE-4F75-3689-BEF6-4A46C8039E70> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x96a31000 - 0x96a99fe7  libvDSP.dylib (380.6) <55780308-4DCA-3B10-9703-EAFC3E13A3FA> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x96a9a000 - 0x96aa2fff  libcopyfile.dylib (89) <4963541B-0254-371B-B29A-B6806888949B> /usr/lib/system/libcopyfile.dylib
0x96aa3000 - 0x96aa7ffe  libcache.dylib (57) <834FDCA7-FE3B-33CC-A12A-E11E202477EC> /usr/lib/system/libcache.dylib
0x96aa8000 - 0x96aa9fff  liblangid.dylib (116) <E13CC8C5-5034-320A-A210-41A2BDE4F846> /usr/lib/liblangid.dylib
0x96aaa000 - 0x96ab4ffe  com.apple.bsd.ServiceManagement (2.0 - 2.0) <9732BA61-D6F6-3644-82DA-FF0D6FEEFC69> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
0x96bb5000 - 0x96bccfff  com.apple.GenerationalStorage (1.1 - 132.3) <DD0AA3DB-376D-37F3-AC5B-17AC9B9E0A63> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalStorage
0x96bcd000 - 0x96bf2ffb  com.apple.framework.familycontrols (4.1 - 410) <B1755756-BEA2-3205-ADAA-68FCC32E60BD> /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A/FamilyControls
0x96bf3000 - 0x96d03ffb  com.apple.QuickTimeImporters.component (7.7.1 - 2599.31) <60E4B0DB-1D43-3BD5-B76C-1069C5E106CF> /System/Library/QuickTime/QuickTimeImporters.component/Contents/MacOS/QuickTimeImporters
0x96d4f000 - 0x96d52ff7  com.apple.TCC (1.0 - 1) <437D76CD-6437-3B55-BE2C-A53508858256> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
0x96d53000 - 0x96d5cfff  com.apple.DiskArbitration (2.5.2 - 2.5.2) <89822A83-B450-3363-8E9C-9B80CB4450B1> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x96d5d000 - 0x96e6aff3  com.apple.ImageIO.framework (3.2.1 - 850) <C964E877-660E-3482-ACF9-EC25DFEAF307> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x96e6b000 - 0x96ecfff7  com.apple.datadetectorscore (4.1 - 269.3) <C11C2014-298E-3E2B-9F5D-02CCD3CA4AB3> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
0x96eda000 - 0x96edafff  com.apple.Accelerate.vecLib (3.8 - vecLib 3.8) <908B8D40-3FB5-3047-B482-3DF95025ECFC> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x96edb000 - 0x96f7bff7  com.apple.QD (3.42.1 - 285.1) <BAAC13D2-1312-33C0-A255-FAB1D314C324> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x9724e000 - 0x97284ffb  com.apple.DebugSymbols (98 - 98) <9A9ADA0A-E487-3C8F-9998-286EE04C235A> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
0x972b6000 - 0x97310fff  com.apple.Symbolication (1.3 - 93) <2C7B4F90-8834-3BCB-81BF-001B31452FB6> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
0x97311000 - 0x9731afff  com.apple.CommerceCore (1.0 - 26.1) <8C28115C-6EC1-316D-9237-F4FBCBB778C5> /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Frameworks/CommerceCore.framework/Versions/A/CommerceCore
0x9731b000 - 0x974d7ffd  libicucore.A.dylib (491.11.3) <FF55E176-7D66-3DBB-AF86-84744C47A02C> /usr/lib/libicucore.A.dylib
0x974d8000 - 0x976c0ffb  com.apple.CoreFoundation (6.8 - 744.19) <DDD3AA21-5B5F-3D8F-B137-AD95FCA89064> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x976c1000 - 0x97703ff7  libcups.2.dylib (327.6) <D994A44F-CCDD-3D40-B732-79CB88F45908> /usr/lib/libcups.2.dylib
0x9773a000 - 0x97740fff  libGFXShared.dylib (8.9.2) <F3B0E66D-5C47-3A5A-A2CD-F0C58E8322C3> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
0x97741000 - 0x97741fff  libsystem_blocks.dylib (59) <3A743C5D-CFA5-37D8-80A8-B6795A9DB04F> /usr/lib/system/libsystem_blocks.dylib
0x97742000 - 0x977d9ff7  com.apple.ink.framework (10.8.2 - 150) <A9C3B735-7D5F-3D7D-AA70-2CC852D09CDE> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x977da000 - 0x97822ff5  com.apple.opencl (2.2.19 - 2.2.19) <968DD067-49D0-3B71-A96B-B3579698D992> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
0x9789f000 - 0x97953fff  com.apple.coreui (2.0 - 181.1) <C15ABF35-B7F5-34ED-A461-386DAF65D96B> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
0x97954000 - 0x97954fff  com.apple.ApplicationServices (45 - 45) <677C4ACC-9D12-366F-8A87-B898AC806DD9> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x97a0d000 - 0x97b48ff7  libBLAS.dylib (1073.4) <FF74A147-05E1-37C4-BC10-7DEB57FE5326> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x97b49000 - 0x97b4afff  libremovefile.dylib (23.2) <9813B2DB-2374-3AA2-99B6-AA2E9897B249> /usr/lib/system/libremovefile.dylib
0x97b4b000 - 0x97bafff3  libstdc++.6.dylib (56) <F8FA490A-8F3C-3645-ABF5-78926CE9C62C> /usr/lib/libstdc++.6.dylib
0x97bb0000 - 0x97bbafff  libsystem_notify.dylib (98.5) <7EEE9475-18F8-3099-B0ED-23A3E528ABE0> /usr/lib/system/libsystem_notify.dylib
0x97bbb000 - 0x97c79ff3  com.apple.ColorSync (4.8.0 - 4.8.0) <EFEDCB37-4F20-3CEC-A185-5D2976E11BAC> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x97dd8000 - 0x97ef4ffb  com.apple.desktopservices (1.7.4 - 1.7.4) <782D711D-7930-324A-9015-686C2F86DBA3> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x97ef5000 - 0x97ef7fff  com.apple.securityhi (4.0 - 55002) <027D2D24-4043-3B43-90F3-112FB46903E8> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x97ef8000 - 0x97ef9fff  libsystem_sandbox.dylib (220.3) <C532F6A6-7E85-38F3-8660-EC1066DF67BE> /usr/lib/system/libsystem_sandbox.dylib
0x97efa000 - 0x97f10fff  com.apple.CFOpenDirectory (10.8 - 151.10) <D90DB5D4-6565-3726-B88A-21336CBE9170> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
0x97f78000 - 0x97f92ffc  libsystem_kernel.dylib (2050.24.15) <9E58DCC0-D5FF-37E1-AA7F-F2206719E138> /usr/lib/system/libsystem_kernel.dylib
0x97f93000 - 0x97fa5fff  libbsm.0.dylib (32) <DADD385E-FE53-3458-94FB-E316A6345108> /usr/lib/libbsm.0.dylib
0x97fa6000 - 0x97fadfff  liblaunch.dylib (442.26.2) <310C99F8-0811-314D-9BB9-D0ED6DFA024B> /usr/lib/system/liblaunch.dylib
0x97fae000 - 0x97faefff  com.apple.Cocoa (6.7 - 19) <354094F0-F36B-36F9-BF5F-FD60590FBEB9> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x980aa000 - 0x980adffc  libpam.2.dylib (20) <FCF74195-A99E-3B07-8E49-688D4A6F1E18> /usr/lib/libpam.2.dylib
0x980ae000 - 0x980ceffd  com.apple.ChunkingLibrary (2.0 - 133.3) <FA45EAE8-BB10-3AEE-9FDC-C0C3A533FF48> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary
0x980cf000 - 0x980d5fff  com.apple.print.framework.Print (8.0 - 258) <12AEAD24-6924-3923-9E4A-C5D21231E639> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x9895f000 - 0x98968ff9  com.apple.CommonAuth (3.0 - 2.0) <34C4768C-EF8D-3DBA-AFB7-09148C8672DB> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
0x98969000 - 0x9899cffb  com.apple.GSS (3.0 - 2.0) <9566A96D-C296-3ABD-A12A-E274C81C0B25> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
0x9899d000 - 0x989a1fff  com.apple.CommonPanels (1.2.5 - 94) <6B3E7E53-7708-3DA2-8C50-59C2B4735DE1> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x989a2000 - 0x989f1ff6  libTIFF.dylib (850) <78E121A6-92A2-3120-883C-7AA3C2966F9C> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x989f2000 - 0x98a07fff  com.apple.ImageCapture (8.0 - 8.0) <B8BD421F-D5A9-3FB4-8E89-AD5CFC0D4030> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x98a0a000 - 0x98a0afff  libkeymgr.dylib (25) <D5E93F7F-9315-3AD6-92C7-941F7B54C490> /usr/lib/system/libkeymgr.dylib
0x98a0b000 - 0x98b59ff3  com.apple.CFNetwork (596.4.3 - 596.4.3) <547BD138-E902-35F0-B6EC-41DD06794B22> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x98b5a000 - 0x98b5dffc  libCoreVMClient.dylib (32.3) <35B63A60-DF0A-3FB3-ABB8-164B246A43CC> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
0x98b5e000 - 0x98ba3ff7  com.apple.NavigationServices (3.7 - 200) <F6531764-6E43-3AF3-ACDD-8A5551EF016A> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationServices.framework/Versions/A/NavigationServices
0x98ba4000 - 0x98be6fff  libauto.dylib (185.4) <3098A75E-438E-3F18-BAAC-CD8F1CC7C2F7> /usr/lib/libauto.dylib
0x98be7000 - 0x98c4dfff  com.apple.print.framework.PrintCore (8.3 - 387.2) <0F7665F5-33F0-3661-9BE2-7DD2890E304B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x98c74000 - 0x98cdcff7  com.apple.framework.IOKit (2.0.1 - 755.24.1) <70DE925B-51E8-3C65-8928-FB49FD823D94> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x98cdd000 - 0x98d62ff7  com.apple.SearchKit (1.4.0 - 1.4.0) <454E950F-291C-3E95-8F35-05CA0AD6B327> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x98fd8000 - 0x992f8ff3  com.apple.Foundation (6.8 - 945.18) <BDC56A93-45C5-3459-B307-65A1CCE702C5> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x993f7000 - 0x993f7fff  com.apple.Accelerate (1.8 - Accelerate 1.8) <4EC0548E-3A3F-310D-A366-47B51D5B6398> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x9952d000 - 0x99584ff7  com.apple.ScalableUserInterface (1.0 - 1) <2B5E454B-BC49-3E85-B54D-1950397C448C> /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks/ScalableUserInterface.framework/Versions/A/ScalableUserInterface
0x99585000 - 0x995c4ff7  com.apple.bom (12.0 - 192) <0637E52C-D151-37B3-904F-8656B2FD44DD> /System/Library/PrivateFrameworks/Bom.framework/Versions/A/Bom
0x996a7000 - 0x9a3dfff7  com.apple.QuickTimeComponents.component (7.7.1 - 2599.31) <A0445D02-A1C1-3D40-8219-D8EA6B28811C> /System/Library/QuickTime/QuickTimeComponents.component/Contents/MacOS/QuickTimeComponents
0x9a3e0000 - 0x9a65cff7  com.apple.QuickTime (7.7.1 - 2599.31) <3839E1F3-7948-3E68-9AE1-A0CEE8C59212> /System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime
0x9a65d000 - 0x9a68efff  com.apple.DictionaryServices (1.2 - 184.4) <A31BB2CE-6965-3610-8B11-EA26EC6D7EEA> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
External Modification Summary:
  Calls made by other processes targeting this process:
    task_for_pid: 1
    thread_create: 0
    thread_set_state: 0
  Calls made by this process:
    task_for_pid: 0
    thread_create: 0
    thread_set_state: 0
  Calls made by all processes on this machine:
    task_for_pid: 717
    thread_create: 1
    thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=188.2M resident=104.3M(55%) swapped_out_or_unallocated=83.9M(45%)
Writable regions: Total=130.9M written=15.8M(12%) resident=45.7M(35%) swapped_out=0K(0%) unallocated=85.2M(65%)
REGION TYPE                      VIRTUAL
ATS (font support)                 33.1M
CG backing stores                  7516K
CG shared images                   1216K
CoreServices                       4124K
MALLOC                             56.1M
MALLOC guard page                    48K
Memory tag=240                        4K
Memory tag=242                       12K
Memory tag=249                      264K
Memory tag=35                      5696K
Stack                              67.6M
VM_ALLOCATE                        16.3M
__DATA                             14.0M
__DATA/__OBJC                       188K
__IMAGE                             528K
__IMPORT                             84K
__LINKEDIT                         44.6M
__OBJC                             1732K
__OBJC/__DATA                       148K
__PAGEZERO                            4K
__TEXT                            143.6M
__UNICODE                           544K
mapped file                       102.1M
shared memory                       308K
TOTAL                             499.3M
Model: MacBookAir5,2, BootROM MBA51.00EF.B02, 2 processors, Intel Core i7, 2 GHz, 8 GB, SMC 2.5f7
Graphics: Intel HD Graphics 4000, Intel HD Graphics 4000, Built-In, 512 MB
Memory Module: BANK 0/DIMM0, 4 GB, DDR3, 1600 MHz, 0x80AD, 0x484D5434353153364D465238412D50422020
Memory Module: BANK 1/DIMM0, 4 GB, DDR3, 1600 MHz, 0x80AD, 0x484D5434353153364D465238412D50422020
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0xE9), Broadcom BCM43xx 1.0 (5.106.98.100.17)
Bluetooth: Version 4.1.4f2 12041, 2 service, 18 devices, 1 incoming serial ports
Network Service: guest, AirPort, en0
Serial ATA Device: APPLE SSD SM512E, 500.28 GB
USB Device: hub_device, 0x8087  (Intel Corporation), 0x0024, 0x1a100000 / 2
USB Device: FaceTime HD Camera (Built-in), apple_vendor_id, 0x8510, 0x1a110000 / 3
USB Device: DigiTech RP155, 0x1210, 0x001b, 0x14200000 / 1
USB Device: hub_device, 0x8087  (Intel Corporation), 0x0024, 0x1d100000 / 2
USB Device: hub_device, apple_vendor_id, 0x9126, 0x1d110000 / 7
USB Device: LaCie Rugged FW/USB, 0x059f  (LaCie), 0x100c, 0x1d113000 / 10
USB Device: LaCie Rugged FW/USB, 0x059f  (LaCie), 0x100c, 0x1d111000 / 8
USB Device: USB 2.0 Hub [MTT], 0x1a40  (TERMINUS TECHNOLOGY INC.), 0x0201, 0x1d112000 / 14
USB Device: USB Receiver, 0x046d  (Logitech Inc.), 0xc526, 0x1d112500 / 18
USB Device: HL-5340D series, 0x04f9  (Brother International Corporation), 0x0039, 0x1d112200 / 17
USB Device: USB Audio CODEC, 0x08bb  (Texas Instruments Japan), 0x2902, 0x1d112700 / 16
USB Device: USB 2.0 Hub, 0x1a40  (TERMINUS TECHNOLOGY INC.), 0x0101, 0x1d112100 / 15
USB Device: iPhone, apple_vendor_id, 0x12a8, 0x1d112120 / 19
USB Device: Display Audio, apple_vendor_id, 0x1105, 0x1d114000 / 13
USB Device: Apple LED Cinema Display, apple_vendor_id, 0x9226, 0x1d116000 / 12
USB Device: Display iSight, apple_vendor_id, 0x8508, 0x1d115000 / 11
USB Device: hub_device, 0x0424  (SMSC), 0x2513, 0x1d180000 / 3
USB Device: BRCM20702 Hub, 0x0a5c  (Broadcom Corp.), 0x4500, 0x1d181000 / 6
USB Device: Bluetooth USB Host Controller, apple_vendor_id, 0x821f, 0x1d181300 / 9
USB Device: Internal Memory Card Reader, apple_vendor_id, 0x8404, 0x1d183000 / 5
USB Device: Apple Internal Keyboard / Trackpad, apple_vendor_id, 0x024c, 0x1d182000 / 4
Reason: added code tags for readability
Post by Gale Andrews » Fri Jul 12, 2013 9:30 am
calmcent wrote:I'm having same problem - just started - can't figure out why.
Thanks for attaching the report.The Digitech RP350 Audio Unit is causing the problem, so move /Library/Audio/Plug-Ins/Components/RP350.component/Contents/MacOS/RP350 to your Desktop so that Audacity cannot find it.
Alternatively follow the steps here http://wiki.audacityteam.org/wiki/User: ... ces_on_Mac to create or edit the audacity.cfg settings file so as to disable all Audio Unit and VST effects in Audacity. Then optionally when Audacity starts, you can go to Audacity > Preferences then choose Effects on the left. Re-enable (put a check in) the three boxes that say "VST", click OK then restart Audacity. This will allow VST effects to load assuming none of those are a problem. If Audacity crashes again, repeat the steps to edit audacity.cfg to disable both VST and Audio Unit effects.
calmcent
Re: Audacity crashes on launch Mac OSX 10.8.2[SOLVED]
Post by calmcent » Fri Jul 12, 2013 1:11 pm
Thank you for that. Everything seems to be working ok now.
