Using Audacity 2.02 and wanted to use click track. It wasn’t in menu under Generate so downloaded
Nyquist Plug-ins. Maybe I didn’t do the right thing. I dragged the folder to the Audacity icon in my
Applications folder. I quit Audacity and now I get this message: Critical Nyquist files could not be
found. Nyquist effects will not work.
Has anyone had this problem? Appreciate your help!
Tamar
You have probably not installed Audacity correctly.
Carefully follow the installation instructions for installing the .dmg file here: http://audacityteam.org/download/mac
thanks! downloaded 2.03 and i see the click track. no time to play with it now, but looks good!
