Auto add extension on export
Help for Audacity on macOS.
LDMartin1959
Post by LDMartin1959 » Wed Dec 19, 2012 4:18 pm
I think I screwed something up. Previously when exporting to a format, I recall Audacity automatically adding the appropriate file extension. I was having trouble with a certain file and decided to try exporting to a different format. Since then, I am having to manually add the extension upon export. I didn't think I changed any of the basic settings but I must have. Anyone got direction for me as to where to go to fix this?
Re: Auto add extension on export
Post by kozikowski » Wed Dec 19, 2012 4:41 pm
Some exports don't have any idea what you want ahead of time. If you export WAV Microsoft signed 16-bit PCM, it should always add the .wav extension. I think there is another way to export WAV that doesn't.
Post by steve » Wed Dec 19, 2012 4:48 pm
Don't use dots "." in the file name.
LDMartin1959
Post by LDMartin1959 » Wed Dec 19, 2012 4:52 pm
kozikowski wrote:Some exports don't have any idea what you want ahead of time. If you export WAV Microsoft signed 16-bit PCM, it should always add the .wav extension. I think there is another way to export WAV that doesn't.
Presently, I am exporting to .M4A. I think that is the same setting I used previously but now it is not adding the extension. Is there another export which gives me the same file format but automatically includes the extension?
steve wrote:Don't use dots "." in the file name.
That may be the issue, but often the original files I am working with have dots "." in the file name. Can't recall if that was the case in the past or note. I'll keep an eye on that, though.
Post by Gale Andrews » Thu Dec 27, 2012 8:54 am
If the file name includes dots then you have to add the extension yourself. See here http://manual.audacityteam.org/o/man/fa ... extensions .
There could be a checkbox to force the appropriate default extension to be added even if the file name has dots. We may do that at some future time.
LDMartin1959
Post by LDMartin1959 » Thu Dec 27, 2012 10:36 pm
Gale Andrews wrote:There could be a checkbox to force the appropriate default extension to be added even if the file name has dots. We may do that at some future time.
That would be a nice convenience.
