Audacity startup problem
Help for Audacity on macOS.
witzthum6
Post by witzthum6 » Tue Dec 18, 2012 9:44 am
I am trying to open audacity on my mac 10.6.8 and it freezes and does not respond every time. I have tried to uninstall it a number of times and install it again and it reacts the same way every time. I have included the error script to this email. Please help. thanks. witzthum6
Re: Audacity startup problem
Post by Gale Andrews » Wed Dec 19, 2012 8:54 am
witzthum6 wrote:I am trying to open audacity on my mac 10.6.8 and it freezes and does not respond every time. I have tried to uninstall it a number of times and install it again and it reacts the same way every time. I have included the error script to this email. Please help. thanks. witzthum6
Nothing was attached. See here for how to attach crash reports:
http://forum.audacityteam.org/viewtopic ... 49&t=64936 .
I moved this from the topic you attached it to, in case the cause of your problem is different. You can always follow the steps I indicated in that topic (see here
http://forum.audacityteam.org/viewtopic ... 28#p178528 ) to modify the audacity.cfg settings file. This will solve the problem in most cases.
However, assuming a VST or Audio Unit plug-in is the problem, you would not be able to run VST or AU plug-ins in Audacity after disabling them in the .cfg file.
