Cassettes to Imac Recording Settings
Help for Audacity on macOS.
snapyou
Post by snapyou » Fri Dec 14, 2012 1:26 pm
I am trying to record cassettes from a basic cassette top my imac.
I have attached them by connecting 3.5mm cable jack into cassette mic socket and other end into Audio In port to Imac.
However,when using Audacity,there only seems to be levels going in when the cassette player's speaker is on.Therefore i am wondering if the recording is only
being done by the imac's mic rather than through the connection?
Do i need to change any Sound settings in the Imac's Sound preferences?
Thanks in advance!
waxcylinder
Re: Cassettes to Imac Recording Settings
Post by waxcylinder » Fri Dec 14, 2012 3:05 pm
This set of tutorials from the Manual should help: http://manual.audacityteam.org/o/man/tu ... to_cd.html
Post by kozikowski » Fri Dec 14, 2012 5:54 pm
On the Mac you're connected to the circle with two black triangles, right?
http://www.kozco.com/tech/audacity/pix/MacLineIn.jpg
The cassette machine connection should be the stereo headphone out, not the Mic-In.
Go to the Audacity input device pulldown (microphone symbol) and make sure you're recording from the Built-In Line-In, not the Mic-In.
Post by kozikowski » Fri Dec 14, 2012 6:03 pm
If it's a big cassette player, they you may have an actual Stereo Line-Out as RCA connections.
http://kozco.com/tech/audacity/pix/MacLine-In.jpg
For that case, you use one of these.
http://kozco.com/tech/audacity/pix/RCAMiniStereo.jpg
snapyou
Post by snapyou » Fri Dec 14, 2012 6:10 pm
kozikowski wrote:On the Mac you're connected to the circle with two black triangles, right?
THANKS ! All connected now BUT when i play back the recording,i get silence though it does seem to have recorded the input. However,it is only recording on left side.
My Mac sound preferences are: OUTPUT:Headphones (also available:soundflower 2ch/soundflower 16ch
INPUT: LINE IN (internal mic/soundflower 2 and 16 also available).
any ideas?
Thanks again!
Post by kozikowski » Fri Dec 14, 2012 6:46 pm
Do you have your earbuds plugged in to the Mac? Isn't there a setting for Built-In Speakers?
So you have this, but you only have one set of waves, not two?
http://kozco.com/tech/audacity/Audacity1_playback.jpg
snapyou
Post by snapyou » Sat Dec 15, 2012 8:15 am
kozikowski wrote:Do you have your earbuds plugged in to the Mac? Isn't there a setting for Built-In Speakers?
Yes,only got one set of waves.Any ideas? (i can now 'hear' the recording though)
Thanks again.
snapyou
Post by snapyou » Sun Dec 16, 2012 2:54 pm
Exported as mp3 to itunes but sound only coming out of one speaker.
Help please!
billw58
Post by billw58 » Sun Dec 16, 2012 7:00 pm
Please describe again exactly how the cassette deck is connected to the iMac. It sounds like you might have a bad cable.
-- Bill
Post by steve » Sun Dec 16, 2012 7:04 pm
Is the jack plug in a mono plug like this:
or a stereo plug like this (note the extra "ring" behind the tip of the plug):
