Pops at edit points
Re: Pops at edit points
Here is a screen shot (if I've done it right). The pops are at about 6.50 and 7.20. I tried to raise the pitch of this note by 2%.
- Attachments
[The extension tiff has been deactivated and can no longer be displayed.]
Most web browsers do not display TIFF images, so I've converted it to a .PNG image.
That looks like a continuous sound with no gaps (silences) or beats to hide the "join", which makes it tricky to apply effects that change the waveform without creating clicks.
What you will probably need to do is to duplicate the selection to a new track, apply the effect to the duplicate, then crossfade from the original to the duplicate and back again at the end.
A simpler method that may work (it's difficult to tell just by looking) is that you may be able to use the Repair effect to smooth out the clicks http://manual.audacityteam.org/o/man/repair.html
Learn more about Nyquist programming at audionyq.com
- Quality Assurance
- Operating System: Windows 10 / 11
OK I'll support that... Find Zero Crossings seems tedious but doesn't stop me recommending it as one of the tools for the job.steve wrote:have an option/function to automatically apply "Repair" to edit points (to each end of the selection).(this would be a "feature request" should you want to support it).
waxcylinder
+1 I'd support that as a FR too.Gale Andrews wrote:OK I'll support that... Find Zero Crossings seems tedious but doesn't stop me recommending it as one of the tools for the job.steve wrote:have an option/function to automatically apply "Repair" to edit points (to each end of the selection).(this would be a "feature request" should you want to support it).
Peter.
