Hey guys,
I'm new here and i tried to search the forum for an answer to my problem but couldnt find any.
A while ago i installed some new waves plugins, after that i wanted to open audacity and it asked for the folder where they were installed.
Because i rarely use plugins in aud. i pressed cancel and after that it stalled. So i waited a while and eventually had to force stop the programme.
Since then everytime i try to open it the icon just keeps jumping up and down in the dock and after 2 minutes or so i get a message that audacity quit unexpectedly.
Even after reinstalling this still occurs.
I really hope someone has an answer to this, thanks in advance!
Audacity crashes on opening after installing Waves plugins
rutgeranton
Reason: Added "waves plugins" to title.
Re: Audacity crashes on opening after previous 'force stop'.
rutgeranton
Thanks for the reply but unfortunately this didnt do the trick.
Check that you are applying Gale's instructions exactly as described,
rutgeranton
I did. I have this .cfg file (wich is recognized as a kontakt file). I opened it with texteditor, changed the script as described in the example and then saved it.
Off course it is then saved as a .rtf file. So i click the filename and change it to .cfg, then it asks if i really want to change it to .cfg and that is what i did.
I assume this is the correct way?
rutgeranton
Allright nevermind. I didnt open the folder via go>go to etc. Now i did that and changed the file again and it seemed to work!
Thanks a bunch.
Thanks a bunch.
Re: Crash on open after installing Waves plugins (SOLVED)
Thanks for letting us know.rutgeranton wrote:Now i did that and changed the file again and it seemed to work!
