Where are plugins?
Help for Audacity on macOS.
MidiVeg
Where are plugins?
Post by MidiVeg » Wed Sep 26, 2012 2:39 am
I have just installed 2.0.2 as well as the LADSPA plug ins. Where ARE those plugins installed, anyway? And is there any way to have them, as well as those that are part of Audacity itself, to be available to Digital Performer (7.24)? When I open DP those plugins are not visible.
I'm on OS 10.8.2
Thanks!
Re: Where are plugins?
Post by steve » Wed Sep 26, 2012 4:00 am
Digital Performer does not support LADSPA plug-ins.
Post by Gale Andrews » Wed Sep 26, 2012 5:13 am
MidiVeg wrote:I have just installed 2.0.2 as well as the LADSPA plug ins. Where ARE those plugins installed, anyway?
/Library/Audio/Plug-Ins/LADSPA, if you did not change the package installation directory.
MidiVeg
Post by MidiVeg » Wed Sep 26, 2012 2:01 pm
Actually, no, that's not where they are. I didn't change anything during the installation, just had the installer put them where ever it put them. Searching for 'LADSPA' doesn't bring up anything either . . . Yet they appear in the application, so they must be somewhere
Post by Gale Andrews » Thu Sep 27, 2012 12:11 am
MidiVeg wrote:>/Library/Audio/Plug-Ins/LADSPA,
Actually, I tested the installer before replying ( http://ardour.org/files/releases/swh-plugins-0.4.15.dmg ).
I agree Finder often does not search folders it thinks you should not mess with, though I cannot understand the rules it operates by.
Have you tried Go > Go to Folder in Finder and typing
Code: Select all
