Automatically delete blank space
Help for Audacity on macOS.
lilears4
Post by lilears4 » Sat Sep 22, 2012 4:35 am
Hi all...
I am hoping someone has a handle on how to do this.
I would like to find a way to automatically scrub a track to remove blank space in speech...
As it stands, I have to manually select the pauses between sentences and even words... then delete them...
For example, if a sentence sounds like this:
"well...... john decided... to... run to the store........ that took a while...... given that he wasn't wearing... any... shoes...."
I would like to make it:
"well john decided to run to the store that took a while given that he wasn't wearing any shoes."
or even:
"welljohndecidedtoruntothestorethattookawhilegiventhathewasn'twearinganyshoes."
Any ideas? Plugins out there? Something I could tweak thresholds and time intervals on?
thanks in advance...
Re: Automatically delete blank space
Post by steve » Sat Sep 22, 2012 10:41 am
