Click Sound after Editing Small Bits
Help for Audacity on macOS.
tomaso
Post by tomaso » Thu Sep 20, 2012 10:00 pm
After I highlight a portion of the song and edit it (whether it be slow down the temp or change the volume) there is always a click/static sound at the start of the portion that was highlighted and at the end of it.
For instance, on a song that is 3:00 minutes long, I want to increase the volume from 2:31-2:39. So I highlight that part and edit it. After I do this, there is always a click/static noise at 2:31 and at 2:39. No matter what I do. Whether it's increasing the volume, adding reverb, increasing or decreasing the tempo. I just want there to be a smooth sound with no interruptions after editing.
Has anyone ever experienced this?
Thanks
Re: Click Sound after Editing Small Bits
Post by steve » Fri Sep 21, 2012 4:57 pm
Clicks at edit points occur if the waveform on the two sides of the edit point do not match up - for example:
This can sometimes be avoided by adjusting the section to be edited to the nearest Zero Crossing Point
If there is still a click, then it can be repaired using the Repair effect: http://manual.audacityteam.org/o/man/repair.html
tomaso
Post by tomaso » Fri Sep 21, 2012 10:53 pm
Thank you! This helps a lot.
