Audacity 2.0.1 crashes on Mac Mountain Lion during recording
Help for Audacity on macOS.
maratique
Post by maratique » Mon Sep 17, 2012 2:01 pm
I love Audacity and have been using it on my PC for years. However, when I recently switched to Mac (Mountain Lion) I found it crashing on me all the time when I record.
My settings are 24 bit 48000 Hz. There is no consistency on when and how it crashes, but mostly it happens on Project Save or in the middle of the recording. Then I can recover my project and continue, but it can happens 10 to 12 times in one our.
The Audacity version that I use is 2.0.1.
Using Presonus Audiobox USB to record guitar and voice on my Mac mini that I bought in 2011 (8Gb of RAM).
Please help,
Re: Audacity 2.0.1 crashes on Mac Mountain Lion during recor
Post by kozikowski » Mon Sep 17, 2012 3:02 pm
All the time you record what? What's the show and how do you have the computer connected? And which computer?
maratique
Post by maratique » Mon Sep 17, 2012 4:41 pm
When I record music and voice. I use Presonus Audiobox USB
Post by kozikowski » Tue Sep 18, 2012 12:04 am
I have a Mini old enough to have one USB connection be erratic. Try a different connection and you consistently have trouble with one, put in a hub for keyboard and mouse and leave the busted one blank. Do Not Run Audacity through a hub. Audacity needs a clean home run.
And don't edit a question with more information. Always add a self-contained comment or response.
Post by Gale Andrews » Tue Sep 18, 2012 12:19 am
You didn't say when you wrote to [email protected] that you were using an external audio device. You could check with Presonus if OS X 10.8 has broken compatibility with the interface. Are you setttng 24-bit 48000 Hz in Apple Audio MIDI Setup as well as in Audacity?
Do you get a crash when recording from the Mac audio input instead of Presonus?
To repeat my response on [email protected]
Is this OS X 10.8.1? There was one other report recently that upgrading from 10.8.0 to 10.8.1 caused Audacity crashes. It may be incidental. but that user found that redownloading Audacity and installing the new download stopped the crashes.
The current Audacity version is 2.0.2:
http://audacityteam.org/download/mac
so I would first of all try that. Reboot the computer before using 2.0.2.
If 2.0.2 crashes, please try resetting the audacity.cfg settings file, following these instructions:
http://manual.audacityteam.org/o/man/pr ... tml#stored .
If the crashes persist, please send us a crash report following these instructions:
http://guides.macrumors.com/Submitting_a_crash_report .
Now you have also posted here it may be easier to continue here.
maratique
Post by maratique » Tue Sep 18, 2012 6:12 pm
I had similar problems when I was in Mac Lion OS.
I did use a hub connecting to Personus. Will try connecting directly to Mac mini USB instead of the USB hub and report back.
