Failure to launch
Help for Audacity on macOS.
jbranch
Failure to launch
Post by jbranch » Sat Sep 15, 2012 3:49 pm
I have an imac 12.1 and I can not get audacity to launch from its icon. I'm new to macs so I do not know how to uninstall and then reinstall. Not eve sure if i need to do the uninstall. Can anyone help me please.
billw58
Re: Failure to launch
Post by billw58 » Sat Sep 15, 2012 6:52 pm
Re-installing won't help. Please see this page http://wiki.audacityteam.org/wiki/User: ... ces_on_Mac for instruction on how to set your preferences so that Audacity will not try to load VST and AU effects.
-- Bill
jbranch
Post by jbranch » Mon Sep 17, 2012 11:52 am
Thank bill I have it fixed now but i have another issue I installed lame so that i can export as mp3 and it will not save for me.....I did type the ext. mp3 plus changed the extension in the format drop box do you think I should not have typed the mp3 ext.....just in case it has two ext.... like ".mp3.mp3"
thank you vry much for your help
Post by steve » Mon Sep 17, 2012 1:47 pm
Audacity will automatically add the .mp3 extension if you just enter the file name (provided that the file name does not contain any dots).
Did you get an error message or warning when trying to export as MP3?
What exactly (step by step) did you do, and what happened?
Post by Gale Andrews » Tue Sep 18, 2012 2:01 am
There is a FAQ that explains this, too:
http://manual.audacityteam.org/o/man/fa ... extensions .
