Imported Files dont work?
Help for Audacity on macOS.
Jenn_Smith12
Post by Jenn_Smith12 » Mon Sep 10, 2012 4:47 pm
I have the 1.2.5 version on my mac and for some reason it doesn't play any imported files. I've tried changing the format to mp3 ect. it doens't seem to do anything. Any advice?
Re: Imported Files dont work?
Post by steve » Mon Sep 10, 2012 5:24 pm
Audacity 1.2.5 is obsolete.
Unless you are running an ancient version of OS X I'd suggest that you upgrade to Audacity 2.0.2 http://audacityteam.org/download/
To add support for additional file types you can install FFMpeg:
http://manual.audacityteam.org/o/man/fa ... tml#ffdown ,
