Yamaha USB audio interface Audiogram6
Help for Audacity on macOS.
Khalidksk
Post by Khalidksk » Mon Sep 10, 2012 11:06 am
I need help, I'm trying to install the computer recording system Yamaha USB audio interface Audiogram6 , the system has CD named CUBASE Al 6 included ,steinberg in my mac
Re: Yamaha USB audio interface Audiogram6
Post by kozikowski » Tue Sep 11, 2012 3:34 am
If the interface is multi-channel, you may be required to use the CUBase software. Audacity doesn't directly support ASIO software for multi-channel sound.
Khalidksk
Post by Khalidksk » Tue Sep 11, 2012 7:50 pm
thanks, i'm still having problem configuring the yamaha USB audio interface Audiogram6 device even with the original software included with the product, once again many thanks.
