Dear Friends,
I have Audacity 2.0.2 and Mac. OS X version 10.7.4. How can I treat a track - like Tchaikovsky's Romeo and Juliet Overture - to make parts of it sound zombie-esque? I would probably want it slowed down, with lower pitch, but also a kind of ghoulish distortion - as though being played underwater, and with palpable distress, but still be faintly recognizable as the Tchaikovsky.
All suggestions gratefully received. Many Thanks, Timothy
zombie effect
billw58
Re: zombie effect
Try Effect > Change Speed and Effect > Tremolo. Extreme settings in Effect > Equalization might achieve the "distortion" you are looking for.
-- Bill
-- Bill
Re: zombie effect
Thank you, Bill. Much appreciated.billw58 wrote:Try Effect > Change Speed and Effect > Tremolo. Extreme settings in Effect > Equalization might achieve the "distortion" you are looking for.
-- Bill
TS
