Best version Audacity for 10.5.8?
Help for Audacity on macOS.
RSchwim
Post by RSchwim » Fri Sep 07, 2012 10:11 pm
Hello--
What version of Audcaity do you think is most compatible w. OS 10.5.8?
Thanks,
Rob
Re: Best version Audacity for 10.5.8?
Post by steve » Fri Sep 07, 2012 10:14 pm
As it says on the download page: http://audacityteam.org/download/
Audacity 2.0.2 for Mac OS X 10.4 or later.
