When I open Help -> Manual in web browser I get "You do not appear to have help installed on this computer".
I'm on Mac Core 2 duo with Lion and installed via .dmg.
Audacity (and the help directory) is not installed in the Applications directory, but the Applications directory has a soft-link to the Audacity directory.
What do I have to do to get help working?
2.0.0 You do not appear to have help installed
- Quality Assurance
Re: 2.0.0 You do not appear to have help installed
2.0.0 is obsolete. I suggest you download the current 2.0.2 and install it according to these instructions:PReinie wrote:When I open Help -> Manual in web browser I get "You do not appear to have help installed on this computer".
http://audacityteam.org/download/mac .
1) Do I have to uninstall/delete/remove 2.0.0 before installing the latest one?
2) Was Help broken in 2.0.0 but fixed in the latest version? (Why doesn't it work in 2.0.0?)
- Quality Assurance
Yes it is better than you unmount and drag to Trash the dmg and any other contents you may have copied from it.PReinie wrote:1) Do I have to uninstall/delete/remove 2.0.0 before installing the latest one?
No - it was never broken.PReinie wrote:2) Was Help broken in 2.0.0 but fixed in the latest version?
I cannot tell you because I cannot see your computer to see where the files are.PReinie wrote:(Why doesn't it work in 2.0.0?)
How do I tell Audacity where the files are?
They're in /Users/<username>/Not OSX native/Applications - OSX alien/Audacity/help/manual
(Basically, I keep all the non-native OSX applications in another directory as it helps me keep track of what external apps I have to restore should I build a new machine, or whatever.)
- Quality Assurance
All you need to do is copy the "Audacity" folder from the mounted .dmg into "/Users/<username>/Not OSX native/Applications - OSX alien" and not change the contents of the Audacity folder. It should not matter where the "Audacity" folder itself is as long as you copied it from the mounted .dmg.PReinie wrote:How do I tell Audacity where the files are?
The "Audacity" folder has a "help" folder and a "manual" folder insider that. The "index.html" page inside that "manual" folder is what Audacity looks for when you press "Help > Manual (in web browser)".
If Audacity cannot open "index.html" (path as above) and if you double-click on that index.html page in Finder and it doesn't open, then probably your file permissions are messed up.
