Audacity on my Mac wont recognize mixer??
So my laptop won't recognize my mixer it will only use the built in microphone to record my mix, if anything what could I do to make audacity or my Mac recognize my mixer. Oh also my mixer is a behringer ddm4000 I used an RCA to headphone cable in my "output A" on my mixer and in the headphone port on the Mac. Help pleease
Re: Audacity on my Mac wont recognize mixer??
If you have two connections on your Mac like this...
http://www.kozco.com/tech/audacity/pix/MacLineIn.jpg
Then plug your mixer into the Line-In, the thin black circle with two arrows. If you only have one connection go into Apple > System Preferences > Hardware > Sound and see if you have settings to turn the connection around; one way is headphone out and the other is Line-In. If you have one one of the newer MacBook Pros, you may not have a stereo Line-In. Look at your instructions or look at the on-line writeup for your Mac.
If you have no stereo Line-In, you can use a stereo USB sound adapter like the UCA-202.
http://www.kozco.com/tech/audacity/pix/ ... Lenovo.jpg
The new 13" MacBook Pro claims to have no stereo Line-In, and the 15" does, but I don't think that's completely accurate. Let us know how you get on.
Yeah its a 2012 macbook pro 13 inch so it only has the one headphone out on it, im going to have to get an outboard sound card or adapter like that i have found one at my local music shop for a decent price. unfortunately i was just looking for a cheap fix until i can afford serato in a month, thanks for the tip though really helped me out. cheers bro
