sound activated recording - want to add buffer
Help for Audacity on macOS.
mai2k3
Post by mai2k3 » Sat Jul 14, 2012 8:40 pm
Hi,
Does anyone know if there is any way to cause Audacity to record some time before and after the threshold is passed? I want to get a smoother recording and not sharp cutting in and out exactly when it passes the threshold.
Thanks
Re: sound activated recording - want to add buffer
Post by Gale Andrews » Sun Jul 15, 2012 12:18 am
It's a feature request not yet implemented - I'll add your vote.
