FFmpeg (0.6.2 OSX 10.4+ DMG) + LAME MP3
Help for Audacity on macOS.
mitchins
Post by mitchins » Tue May 29, 2012 9:51 am
Download problems?
I can't even access the webpage to down load the files. The page just freezes!
Reason: Topic split
Re: FFmpeg (0.6.2 OSX 10.4+ DMG) + LAME MP3
Post by steve » Tue May 29, 2012 5:41 pm
Which link are you using?
mitchins
Post by mitchins » Tue May 29, 2012 11:46 pm
The good gremlins have been at work overnight! I thought I'd try once more before replying to your post, and the links are now working. Download is now done.
Thank you for your prompt response to my request.
