Adjust Input Volume?
Help for Audacity 2.x.x on Mac OS X.
ImageThis forum is for Audacity 2.x.x on Mac OS X 10.4 and later.
John S
Post by John S » Mon May 21, 2012 10:58 pm
I am using Mac OS 10.6.8 and Audacity 2.0 downloaded with dmg. I am attempting to record from a phono/usb input, and I am unable to adjust my input volume. The input control slider in Audacity is unavailable but appears to be set at maximum (the output slider works). Similarly, the sliders for the volume adjustment for the USB Audio CODEC in the "Audio MIDI Setup" is unavailable, and appear to be set at "0" with no indication for "value" or "dB". What am I doing wrong?
Thanks for any info.
billw58
Re: Adjust Input Volume?
Post by billw58 » Mon May 21, 2012 11:11 pm
You're not doing anything wrong. USB input devices do not have software input level controls.
http://wiki.audacityteam.org/wiki/User: ... ut_devices
-- Bill
John S
Post by John S » Mon May 21, 2012 11:17 pm
Well that explains that! Thanks.
pbergerd
Operating System: OS X 10.6 Snow Leopard or earlier
Post by pbergerd » Sat Dec 01, 2018 9:28 pm
I have the same situation. My problem is that the output level for my raw Audacity files is very low. Is there no way to increase the input levels to get a better range? (PS: I don't have this problem when using Windows 7).
