Audacity messed up my system audio
Help for Audacity on macOS.
phila_hfi
Post by phila_hfi » Fri May 11, 2012 7:42 pm
Since installing Audacity 2.0 on my Mac, I cannot hear anything but the faintest audio when my speakers are balanced dead center. In order to hear audio out of any program, I have to slide the balance to the left or right. It's very odd. Has anyone else experienced this glitch?
Re: Audacity messed up my system audio
Post by kozikowski » Fri May 11, 2012 8:12 pm
What kind of Mac? Does it happen on earbuds connected to the Mac? Do you use SoundFlower to record internet audio? Do you have Skype?
Download and play this short 38 second clip. Play it first with Audacity closed. Browser player or QuickTime Player.
http://www.kozco.com/tech/LRMonoPhaset4.wav
It's a sound test tool. It's in four segments. Left, Right, Mono, and Phase Reversed. You should be able to hear all four, but the last one should sound a little funny. Let us know if one of the segments drops out or greatly changes volume.
