Automatic segmentation/Remove silent sections
Help for Audacity on macOS.
sloria1
Post by sloria1 » Sun Apr 08, 2012 10:52 pm
I need to simultaneously split a file into multiple files with silent sections removed. I have tried the Truncate Silence tool, but it only removes silence on a single track; it does not segment the file into multiple files.
I would also like to perform this in batch, so that I could take a folder of audio files and split each one into multiple files, with the split files in one folder for each original file.
Thank you advance,
Steve
Re: Automatic segmentation/Remove silent sections
Post by steve » Mon Apr 09, 2012 1:08 am
You could use the SoundFinder tool (Analyze menu) to mark the non-silent sections, then use Export Multiple to export the labelled sections.
See here: http://manual.audacityteam.org/man/Spli ... ate_tracks
Audacity does not currently support Export Multiple or SoundFinder in batch mode.
