3rd party plugins not saving settings in Macro setup
Hi
I am using a MacBook Pro 2020, Mac OS Monterrey 12.6 and Audacity 3.2.3
I bought Izotope RX 10 and a couple of Waves plugins (NS1 and CL Vocals).
When I use Audacity to set up a macro (automated plugin chain) the RX and and Wave plugins save only as default.
No matter how much I tweak and save when I check or use the Macro, all those plugins always show up as default and not my custom settings.
Is it possible to get this to work?
Also I see all the RX plugins under Audacity Effects menu, labeled "RX and [plugin name] BUT I don’t see any of the EQ plugins. Does EQ have to be used in the RX standalone or is it listed under a different name in the Effects plugin list (not under RX)?
Thank you.
