MacOS Big Sur 11.6.8
Focusrite Scarlett 18i20
Rode NT1A
Audacity 3.1.3
I need to turn off sotware playthrough while I’m recording.
On Transport Options software playthrough is unchecked, but I keep getting on my headphones the sound I’m recording.
Your support will be gratefully appreciated.
Thanks in advance.
Mac OS 12.6. I’m using a Yeticaster and recording my voice for a screen cast. When I press any key a loud pop comes through my speaker. I have turned off play through and it does not have any effect. I have unticked all the recording options.
This affects other software. If I try to record in Camtasia or AudioHijack the same sounds are recorded. If I close Audacity they vanish.
Can anyone please explain what is going on?
It took me ages to realise that it was Audacity causing the problem in the other software.
Cheers
Peter
