I assume you can play the files with other software?
You don’t normally need FFmpeg to open MP3s but sometimes it helps with “imperfect” MP3s.
Audacity is more “picky” about than most software but if you can play the files you can probably convert them to WAV with a 3rd-party conversion program. (I’m a Windows guy so I can’t recommend one… iTunes might be able to convert it to WAV.)
On a technical note, this is a bug in mad (which last got updated in 2004). Audacity 3.2 will switch to mpg123 (last updated 2 days ago) which shouldn’t run into this issue. You can download the current alpha on https://audacityteam.org/nightly and see if it works for you there.
I just imported those audio recordings (school lessons) from my Android phone to my MAC and parked in the downloads directory.
Then I had Audacity open those mp3 files
Now: 20% of time Audacity opens those files.
80% of time I got this error: (see snapshots below)
by the way, if the files are encoded as aac > NO problem at all.
Since you don’t like my easy solution… [u]MP3 Diags[/u] can often diagnose & repair MP3s.
It also wouldn’t hurt to check the files with [u]MediaInfoOnline[/u] to make sure they are really MP3s. That sometimes happens and if it’s actually an AAC file, simply renaming it should solve the problem.
If it’s really an MP3, MediaInfo will report:
MPEG Audio
Version 1
Layer 3
…And a bunch of other information. (But it doesn’t seem to find errors.)
I have downloaded and installed Audacity 3.2.0 alpha.
Now I don’t get the error message, however the waveform does NOT appear, so I can do nothing, no audio-editing.
Maybe shall I wait for the stable 3.2.0 version? When do you expect to release it?
Been having this with some, but not all, mp3 files starting today.
Came up with a solution that does not require installing new software!
Open the mp3 in the Music app.
Click on File > Convert > Create mp3 Version
The new mp3 should be a valid mp3 usable by Audacity!
