Hi all,
I’ve read through many similar posts here but nothing seems to be working.
A long project was recorded, and while saving at the end the computer restarted. I was left with e00>d01,d02,d03 etc, each with hundreds of .au files, but no .aup file.
After being able to recover the .aup file and putting it in the same folder as the data file, I tried to open it but get “Error opening project” "Couldn’t find the project data folder:___"
Both the project.aup and project_data folders both within the same folder (nothing else in there). I also opened the project.aup file in a text editor and updated the projectname attribute to be identical to that of the .aup file. So now what I have in the same folder is:
/project.aup (the file), and
/project_data (the folder containing the above mentioned folders and files)
Here is that project code block
<project xmlns="http://audacity.sourceforge.net/xml/" projname="project_data" version="1.3.0" audacityversion="2.2.2" sel0="6986.2806349206" sel1="6986.2806349206" vpos="0" h="6979.7558276644" zoom="86.1328125000" rate="44100.0" snapto="off" selectionformat="hh:mm:ss + milliseconds" frequencyformat="Hz" bandwidthformat="octaves">
That said, this appears to have been recorded in 2.2.2 (according to this block) and I’m working on Audacity 3.1.3, if this means anything.
I’m also running MacOS 10.15.7.
I also tried to download 2.2.2 to see if opening it in that would help, but it continually crashed and I downloaded 2.4.2, also with no luck opening it. I get the same error messages but a different log.
Here are the error codes from the 3.1.3 log along with the support data generated:
13:56:12: File name is /path/project.aup
13:56:12: Mime type is *
13:56:12: Opening with legacyaup
13:56:12: Open(/path/project.aup) succeeded
13:56:13: Error: Internal error in importer...tag not recognized
13:49:19: Audacity 3.1.3
13:49:19: sqlite3 message: (1) no such table: project in "SELECT 1 FROM project LIMIT 1;"
13:49:19: Error: dlopen(/Library/Application Support/audacity/libs/ffmpeg.58.64bit.dylib, 2): image not found
13:49:19: Error: dlopen(/usr/local/lib/audacity/ffmpeg.58.64bit.dylib, 2): image not found
13:49:19: Error: dlopen(ffmpeg.58.64bit.dylib, 2): image not found
13:49:19: Error: Failed to load ffmpeg.58.64bit.dylib ((null))
13:49:19: Error: dlopen(/Library/Application Support/audacity/libs/libavformat.58.dylib, 2): image not found
13:49:19: Error: dlopen(/usr/local/lib/audacity/libavformat.58.dylib, 2): image not found
13:49:19: Error: dlopen(libavformat.58.dylib, 2): image not found
13:49:19: Error: Failed to load libavformat.58.dylib ((null))
13:49:19: Error: dlopen(/Library/Application Support/audacity/libs/ffmpeg.57.64bit.dylib, 2): image not found
13:49:19: Error: dlopen(/usr/local/lib/audacity/ffmpeg.57.64bit.dylib, 2): image not found
13:49:19: Error: dlopen(ffmpeg.57.64bit.dylib, 2): image not found
13:49:19: Error: Failed to load ffmpeg.57.64bit.dylib ((null))
13:49:19: Error: dlopen(/Library/Application Support/audacity/libs/libavformat.57.dylib, 2): image not found
13:49:19: Error: dlopen(/usr/local/lib/audacity/libavformat.57.dylib, 2): image not found
13:49:19: Error: dlopen(libavformat.57.dylib, 2): image not found
13:49:19: Error: Failed to load libavformat.57.dylib ((null))
13:49:19: Error: dlopen(/Library/Application Support/audacity/libs/ffmpeg.55.64bit.dylib, 2): image not found
13:49:19: Error: dlopen(/usr/local/lib/audacity/ffmpeg.55.64bit.dylib, 2): image not found
13:49:19: Error: dlopen(ffmpeg.55.64bit.dylib, 2): image not found
13:49:19: Error: Failed to load ffmpeg.55.64bit.dylib ((null))
13:49:19: Error: dlopen(/Library/Application Support/audacity/libs/libavformat.55.dylib, 2): image not found
13:49:19: Error: dlopen(/usr/local/lib/audacity/libavformat.55.dylib, 2): image not found
13:49:19: Error: dlopen(libavformat.55.dylib, 2): image not found
13:49:19: Error: Failed to load libavformat.55.dylib ((null))
13:49:19: File name is /path/project.aup
13:49:19: Mime type is *
13:49:19: Opening with legacyaup
13:49:19: Open(/path/project.aup) succeeded
13:49:22: Error: Internal error in importer...tag not recognized
13:49:48: sqlite3 message: (1) no such table: project in "SELECT 1 FROM project LIMIT 1;"
13:52:46: File name is /path/project.aup
13:52:46: Mime type is *
13:52:46: Opening with legacyaup
13:52:46: Open(/path/project.aup) succeeded
13:52:48: Error: Internal error in importer...tag not recognized
13:53:37: File name is /path/project.aup
13:53:37: Mime type is *
13:53:37: Opening with legacyaup
13:53:37: Open(/path/project.aup) succeeded
13:53:38: Error: Internal error in importer...tag not recognized
13:54:22: File name is /path/project.aup
13:54:22: Mime type is *
13:54:22: Opening with legacyaup
13:54:22: Open(/path/project.aup) succeeded
13:54:24: Error: Internal error in importer...tag not recognized
Here are the logs from 2.4.2:
13:29:10: Audacity 2.4.2
13:29:10: Trying to load FFmpeg libraries...
13:29:10: Trying to load FFmpeg libraries from default path, '/Library/Application Support/audacity/libs/ffmpeg.55.64bit.dylib'.
13:29:10: Checking for monolithic avformat from '/Library/Application Support/audacity/libs/ffmpeg.55.64bit.dylib'.
13:29:10: Error: dlopen(/Library/Application Support/audacity/libs/ffmpeg.55.64bit.dylib, 1): image not found
13:29:10: Loading avutil from ''.
13:29:10: Error: dlopen(.bundle, 1): image not found
13:29:10: Loading avcodec from ''.
13:29:10: Loading avformat from '/Library/Application Support/audacity/libs/ffmpeg.55.64bit.dylib'.
13:29:10: Error: Failed to load FFmpeg libraries.
13:29:10: Trying to load FFmpeg libraries from legacy path, '/usr/local/lib/audacity/ffmpeg.55.64bit.dylib'.
13:29:10: Checking for monolithic avformat from '/usr/local/lib/audacity/ffmpeg.55.64bit.dylib'.
13:29:10: Error: dlopen(/usr/local/lib/audacity/ffmpeg.55.64bit.dylib, 1): image not found
13:29:10: Loading avformat from '/usr/local/lib/audacity/ffmpeg.55.64bit.dylib'.
13:29:10: Trying to load FFmpeg libraries from system paths. File name is 'ffmpeg.55.64bit.dylib'.
13:29:10: Checking for monolithic avformat from 'ffmpeg.55.64bit.dylib'.
13:29:10: Error: dlopen(ffmpeg.55.64bit.dylib, 1): image not found
13:29:10: Loading avformat from 'ffmpeg.55.64bit.dylib'.
13:29:10: Error: Failed to find compatible FFmpeg libraries.
13:29:14: Error: Could not parse file "/path/project.aup".
Error: Could not load file: "/path/project.aup"
I hope this isn’t information overload, but I tried to provide more rather than less.
I also changed exact path names to just /path/ in the logs to not divulge personal info here.
What might my recourse here be?
Thanks a lot!
