Track markers
After recording my vinyl say 10 songs, they record as 1 track. Can I place markers after each song manually to make the 10 tracks?
If you’re making a CD you add markers using a cue sheet with your burning software. If you’re going to play the files on a computer you’ll need to make a separate file for each song. If you buy an album from Amazon or iTunes you get separate songs.
You can select/highlight one song at a time and then File → Export → Export Selected Audio, or you can [u]Label the tracks and then use the Export Multiple[/u] option.
