What I’m trying to do:
Apply a macro to files in a specific folder
What’s happening: #1 If no project is open then the only menus I get are “Files” and “Windows.” Full stop.
#2 If I have a project open and I go to “Tools > Macros…” and select “Files…” I get a message that tells me to save and close the current project. If I do that, see #1 above. Or I can reopen the project and repeat this item…to no avail.
This doesn’t apply to you, but one common Macro failure is the inability to make decisions. IF/THEN is completely missing. “IF the sound isn’t loud enough THEN do this.” Nope. Can’t do that.
People want Macros to take over their editing jobs and it won’t do that, either.
Both of those choices get the same result (posted originally).
I’m not trying to do anything other than change the temp and pitch of some mp3 files in a folder. Which works fine if run on an individual file manually.
