Muting Separate Audio Segments
Is it possible to mute a separate audio segment on a track instead of muting the entire track?
If you want to permanently mute a section, you can just select it, then “Ctrl + L” (Silence Audio).
(see: https://manual.audacityteam.org/man/edit_menu_remove_special.html)
Or you could select the selection and use Edit > Clip Boundaries > Split New
This would then move the selection to a new track thereby enabling you to mute that independently of the donor track.
Peter.
Thank you both Steve and Wax!
With that, I wanted to add my second problem which I solved immediately from online research today, and posting it now here. How do we ‘import’ a second audio track, underneath the song, for example, to add a mic recording singing?
Go to: File, Import… and choose the format
Next, choose the file, and it will appear underneath your main track!
This is used for merging music.
