My Mac is recognizing my USB Microphone, but when I open Audacity (downloaded today 7 22 21) it does not list it as one of my options.
I have already followed steps listed in this forum for similar problems, but still no solution.
Which steps did you follow?
Quit Audacity. Go to Apple (menu) > System Preferences > Sound > Input. Is the USB microphone listed there? If you speak into it, does the input level meter bounce?
Now start Audacity. Is the USB microphone listed as a recording device?
– Bill
Also, check that you have permission to use the microphone: https://support.apple.com/guide/mac-help/control-access-to-your-microphone-on-mac-mchla1b1e1fe/mac
And post back which steps worked. We use that info to help others.
