The FFmpeg library is located in library/application/support/audacity/libs and I have shown audacity this location several times (in preferences/libraries). However, it consistently tells me that the library is not found. The screenshot below shows that it is there, but going to the respective folder and opening the library has no effect. Quitting and re-opening the app results in the same window as before (2nd screenshot).
Sorry for the German language, I don’t know how to change it to English.
I have spent hours googling this problem, you are my last hope! Thank you in advance!
System: iMac 2020, macOS Catalina 10.15.7, Audacity v. 3.0.2
