AutoSave
Help for Audacity on macOS.
kmarler
AutoSave
Post by kmarler » Thu May 13, 2021 3:03 pm
Hey ya'll !
Is there an autosave feature that I can turn on in Audacity ?
Thanks !
Kyle
Re: AutoSave
Post by steve » Thu May 13, 2021 3:10 pm
No there isn't, but you can save a backup copy of your work at any time except during recording: https://manual.audacityteam.org/man/fil ... oject.html
On large projects, saving can take a significant amount of time, so auto-save would be quite annoying in cases where it would be most beneficial.
