Dot TXT??
Help for Audacity on macOS.
Dot TXT??
Post by kozikowski » Tue Apr 20, 2021 12:55 am
Somebody said Tools > Nyquist Plugin Installer "knows" how to get rid of the .txt that some computers insist on appending to nyquist download filenames.
Is this a fact and how far back in Audacity history does that go?
Re: Dot TXT??
Post by steve » Tue Apr 20, 2021 2:12 am
That would have been me.
It goes back to when it was first shipped with Audacity. 21st Mar 2019, Version 2.3.1
Code: Select all
;If string ends in ".ny.txt", replace with ".ny"
(defun fix-ext (fname)
  (setf ln (length fname))
  (if (and (> ln 7)
           (string-equal (subseq fname (- ln 7) ln) ".ny.txt"))
    (subseq fname 0 (- ln 4))
    fname))
