version 3.0.0
Help for Audacity on macOS.
charlen
Operating System: macOS 10.12 Sierra
Re: version 3.0.0
Post by charlen » Tue May 04, 2021 1:44 pm
hello
mac book pro sierra 10-12-6 Adcty 3.00
* after i reset configurations / and add a short cut " Shft + Cmd + S" assigned to Backup project " and not " save project as "
i get an nornal aup3
but
say the score is " aup 20 " , and i backup as aup 21 , it backup ok , but !
do not automatically up date the score to " aup 21 "
to get aup 21 i have to re-install the whole score .
* when i use " save project as " i get this see attachement .
i do not understand the meaning of this message .
Re: version 3.0.0
Post by steve » Tue May 04, 2021 1:56 pm
I would highly recommend that you update to Audacity 3.0.2 as it fixes some known bugs that are in Audacity 3.0.0.
What do you mean by "score"?
charlen
Re: version 3.0.0
Post by charlen » Tue May 04, 2021 2:16 pm
this i means by score [ attachement ]
Screen Shot 2021-05-04 at 4.08.32 PM.png (207.51 KiB) Viewed 173 times
charlen
Re: version 3.0.0
Post by charlen » Tue May 04, 2021 2:40 pm
i installed 3.0.2 ok
* i got the same
Screen Shot 2021-05-04 at 4.26.29 PM.png (28.84 KiB) Viewed 165 times
what does it mean ??
* and the same
normal backup aup3 but do not actualise the saving on the top of the screen.... is gloo-gloo- fini + 85
the last backup is gloo-gloo- fini + 88
* general donations not possible out of paypal or crypto ?
Re: version 3.0.0
Post by steve » Tue May 04, 2021 2:48 pm
Yes, that is intentional.
Save Project As...
After a standard "Save Project As...", the project that you are currently working on is the project that you have just saved.
So, for example, if you are working on a project called "Aud20.aup" and then "Save Project As..." and save it as "Aud21.aup", then the "Aup20.aup3" project is closed, and you are now working on the freshly saved "Aud21.aup".
"Save Project As..." is useful when you want to copy or rename a project.
One thing to be careful of when using "Save Project As..." is that it only saves your changes to the NEW project, not to the original project.
Backup Project...
This is different from "Save Project As..." in that you can continue to work on the original project.
For example, if you are working on a project called "Aud20.aup" and then "Save Backup..." and create a backup copy called "Aud21.aup", then the "Aup20.aup3" project remains open, and you are still working on the original "Aud20.aup".
"Save Backup..." is useful when you want to make a backup copy of the current state of your project.
One thing to be careful of when using "Save Backup..." is that it only saves to the BACKUP project. It does NOT update the AUP3 that you are currently working on.
Re: version 3.0.0
Post by steve » Tue May 04, 2021 2:51 pm
It is just informing you that you are saving an "Audacity Project", not an "audio file".
You can safely tick the "Don't show this warning again" button so that it does not pop up in future.
charlen
Re: version 3.0.0
Post by charlen » Tue May 04, 2021 3:27 pm
a DEEP thanks bow ! for thoses clean and clears informations .
