Orphan Block Files Error and Empty/Silent Audio
Help for Audacity on macOS.
sanchezs
Post by sanchezs » Sun Feb 21, 2021 11:30 pm
Hi. I really hope there can be solution to this. :(
Basically, I hadn't used Audacity in a while. But the last time I used it, I recorded a pretty good piece on a song that took me ages to perfect. I saved the project and I remember that it was all fine. I must've had that project open another time and Audacity must've crashed.
I am now getting the Orphan Block File(s) Warning for 240 orphan block files. When selecting the "Continue without deleting" option, the audio tracks are there. The length for each recorded bit is there. But they are flat, completely silent and there no waves whatsoever. Super disappointing...
The weird bit is that I can actually go into the _data folder for that project and a lot of the sound files actually contain the sound data! I can play them and I can hear them!!! but obviously as they are super small, there'd be no way of putting all of that back together.
Really hoping someone can help me here...
These are my logs:
Code: Select all
23:13:51: Audacity 2.4.2
23:13:51: Trying to load FFmpeg libraries...
23:13:51: Trying to load FFmpeg libraries from default path, '/Library/Application Support/audacity/libs/ffmpeg.55.64bit.dylib'.
23:13:51: Checking for monolithic avformat from '/Library/Application Support/audacity/libs/ffmpeg.55.64bit.dylib'.
23:13:51: Error: dlopen(/Library/Application Support/audacity/libs/ffmpeg.55.64bit.dylib, 1): image not found
23:13:51: Loading avutil from ''.
23:13:51: Error: dlopen(.bundle, 1): image not found
23:13:51: Loading avcodec from ''.
23:13:51: Loading avformat from '/Library/Application Support/audacity/libs/ffmpeg.55.64bit.dylib'.
23:13:51: Error: Failed to load FFmpeg libraries.
23:13:51: Trying to load FFmpeg libraries from legacy path, '/usr/local/lib/audacity/ffmpeg.55.64bit.dylib'.
23:13:51: Checking for monolithic avformat from '/usr/local/lib/audacity/ffmpeg.55.64bit.dylib'.
23:13:51: Error: dlopen(/usr/local/lib/audacity/ffmpeg.55.64bit.dylib, 1): image not found
23:13:51: Loading avformat from '/usr/local/lib/audacity/ffmpeg.55.64bit.dylib'.
23:13:51: Trying to load FFmpeg libraries from system paths. File name is 'ffmpeg.55.64bit.dylib'.
23:13:51: Checking for monolithic avformat from 'ffmpeg.55.64bit.dylib'.
23:13:51: Error: dlopen(ffmpeg.55.64bit.dylib, 1): image not found
23:13:51: Loading avformat from 'ffmpeg.55.64bit.dylib'.
23:13:51: Error: Failed to find compatible FFmpeg libraries.
23:15:23: File name is /Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1f64a.au
23:15:23: Mime type is *
23:15:23: Opening with libsndfile
23:15:23: Open(/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1f64a.au) succeeded
23:15:41: File name is /Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1f324.au
23:15:41: Mime type is *
23:15:41: Opening with libsndfile
23:15:41: Open(/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1f324.au) succeeded
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1fd44.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1f0b7.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1fda0.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1f0ee.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1faa9.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1f709.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1fa79.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1fdfb.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1f2dc.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1f758.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1fe6f.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1fd60.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1fe14.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1fdf5.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1f275.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1f084.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1fe7b.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1f7e9.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1f989.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1fc88.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1f7a8.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1f2cb.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1f29e.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1f32f.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1ff23.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1fe75.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1f2f5.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1fd41.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1ffe2.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1f153.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1fb88.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1f35b.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1fc99.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1ff1a.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1f04e.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1f1fe.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1f0e7.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1f1d6.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1f324.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1f09f.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1fd9e.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1f08f.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1fd7f.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1f240.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1f300.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1fd30.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1f795.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1f544.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1fc96.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1f570.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1fbb0.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1f940.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1f7c2.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1fcbf.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1f90f.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1fb3b.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1f69c.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1f82c.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1f92b.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1f0e8.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1f069.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1f7ce.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1f6bd.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1fb1f.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1f593.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1f602.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1f8b1.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1f5e1.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1fb15.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1f6b7.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1f7f7.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1f8c5.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1f921.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1fbef.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1f7dd.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1f7ae.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1f781.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1f717.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1f6c7.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1f597.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1fbc4.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1f7c7.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1f4f1.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1fcdf.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1f66e.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1f64a.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1f80b.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1f8cc.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1f46c.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1fc5c.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1fb1c.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1f633.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1f930.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1fc83.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1fac2.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1f992.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1fbe0.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1f815.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1f747.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1f4a4.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1fbf4.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1fbd4.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1f9a5.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1f9d4.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1f520.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1fb41.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1faed.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1f72a.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1faca.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1f83b.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1f4fb.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1f64e.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1f712.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1fbc1.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1f6e7.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1f825.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1f444.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1f614.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1f576.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1f527.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1fc90.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1f890.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1fc2e.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1f329.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1fd19.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1f81a.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1fc0a.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1fa7b.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1fa14.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1f836.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1f797.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1fa71.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1f641.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1f802.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1f463.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1fbce.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1f77c.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1f259.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1fa0c.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1fed8.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1fde9.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1f85d.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1f70f.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1fa92.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1f5e3.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1fb52.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1f4d2.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1f696.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1f995.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1f8d6.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1fa55.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1f966.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1f665.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1fab4.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1f895.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1fc66.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1f547.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1f8f3.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1f4e3.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1f47e.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1fa5c.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1f3f8.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1f6db.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1fd69.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1fcfd.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1f563.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1f4d3.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1fb53.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1fca6.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1fc76.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1fb47.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1f3a9.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1f8ba.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1f3e8.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1f229.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1fa2b.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1ff88.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1fb2e.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1f62f.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1f9e2.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1f6e1.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1f823.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1fb57.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1fbf6.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1f9f6.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1f1e5.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1fee6.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1f041.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1f21a.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1fe3a.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1f5f9.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1f362.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1ff21.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1fe77.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1fed6.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1f174.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1f045.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1fef6.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1f376.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1fe32.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1f06f.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1fe2e.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1f00c.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1fcc9.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1f5d9.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1f8f8.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1f568.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1fc49.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1ffff.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1fe80.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1fe16.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1f277.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1ff25.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1f144.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1f1b4.au'
23:19:04: Warning: Orphan block file: '/Users/sandriskupavskis/Documents/Music/Unknown (Distance)/Distance only bridge_data/eff/d1f/eff1f266.au'
Re: Orphan Block Files Error and Empty/Silent Audio
Post by steve » Mon Feb 22, 2021 11:24 am
That sounds possible - or perhaps you had the project open in Audacity (possibly minimized) and shut down the computer while the project was still open.
What has happened is that the data files in the _data folder don't match up with the .AUP file.
I don't think there's any way to recover the project.
The next version of Audacity should be better in this respect because the project format is changing to a single ".aup3" file, rather that the current "pile of files" format. The release will be announced here on the forum, the Audacity website (https://www.audacityteam.org/) facebook and twitter (links at top of this page).
