Unable to open .ny downloads
Help for Audacity on macOS.
jozi
Post by jozi » Sun Feb 21, 2021 9:19 pm
Mac 10.9.5 Audacity ver 2.3.3
I've downloaded the ACX check plugin and dragged the downloaded file into the audacity plugins folder, but when I try to open it, I get a message stating that "there is no application set to open the document acx check.ny". According to the plugin manager, the plugin installer is enabled. In fact, i'm getting the same message on each and every .ny file in the plugins folder.
Re: Unable to open .ny downloads
Post by kozikowski » Sun Feb 21, 2021 9:35 pm
You should probably be in Audacity 2.4.2 rather than 2.3.3. Some earlier Audacity versions had file export problems.
https://www.audacityteam.org/download/mac/
Once you get there, Tools > Nyquist Plugin Installer
That will install the tool for you.
After you install it, open up Analyze > Add/Remove Plugins and enable it.
It's possible to fake out ACX Check, but for the most part, it tracks with ACX's own analysis tools—and it's a lot faster.
We offer Audacity Audiobook Mastering to bring your presentation up to technical conformance—if you're already close.
This is the short versions. Also really, really, really handy to be in Audacity 2.4.2.
