I observe/mesure exactly a different latency (typically 200-400 ms) , from time to time , when doing many recordings (wh
Help for Audacity on macOS.
XavierRodet
Post by XavierRodet » Thu Feb 18, 2021 1:20 pm
I already published that in another topic, no real explanation or solution, and was said better to start a new one
Here it is !
XavierRodet
Re: Recording new track to saved project in sync, when playback new track is out of time but in time by itself seperatel
Post by XavierRodet » Thu Jan 28, 2021 6:14 pm
MacOS Big Sur V 11.1 5(0C69) SSD hard Disk Audacity 2.3.3 Great Software !!!!
I am new ( Thursday Jan. 28 2021 ) on the Forum. At the moment I cannnt find the proper answer, thank yu in advance
Input & output through USB --> Diamon Sound Tube (a simple sound "card")
I observe/mesure exactly a different latency (typically 200-400 ms) , from time to time , when doing many recordings (while playing sumultaneously for play along/playback usage)
though WITHOUT change :
no change of hardware
no restart of Audacity
no change of Sample Rate
what else ?
The only (I believe) things I change are:
* the zoom in the window where I play and record simultaneously for play along or playback usage
* a New Window for the play along and recording tracks
* Put the Mac to sleep (a correct translation for the French "Suspendre l’activité d’un Mac" ? ... acording to gogol...)
Of course, after measuring it , I can compensate exactly (I use click tracks) but it is annoying and time consuming.
Even if no solution, I would be happy to know WHEN / HOW it occurs ????
Any hint ???
Thank you in advance !
Xavier Rodet
Top
Re: I observe/mesure exactly a different latency (typically 200-400 ms) , from time to time , when doing many recordings
Post by steve » Fri Feb 19, 2021 2:00 am
The latency is likely to change if there are any changes to the sound system, such as changing the device, changing the sample rate, changing the bit format. I don't know why the latency would change if there are no changes to the sound system - that doesn't happen for me.
