electro brand cassette converter
Help for Audacity on macOS.
lougia
Operating System: macOS 10.14 Mojave
Post by lougia » Wed Feb 17, 2021 4:44 pm
Anybody have experience with the electro brand model 2036 USB cassette converter?
I cannot get Audacity to recognize the device so I cannot input any audio. I can set the Audacity Preferences for the device,
and the device shows up in my Mac's Sound Preferences. In fact I can see audio is coming into the Mac from the device but
I can't figure out how to make Audacity see it. Maybe the Electro Brand is a dud? Maybe I should chuck and look for the device mentioned by other here,..the Behringer?
THanks for any thoughts. Lou
billw58
Re: electro brand cassette converter
Post by billw58 » Wed Feb 17, 2021 7:46 pm
In System Preferences > Security & Privacy > Privacy, does Audacity have permission to access the Microphone?
-- Bill
lougia
Post by lougia » Fri Feb 19, 2021 4:44 pm
Thanks Bill. Seemed counterintuitive but it worked.
billw58
Post by billw58 » Fri Feb 19, 2021 6:21 pm
Agreed. To Apple, "microphone" means "any audio input".
-- Bill
