Help!
I am trying to add the Nyqiust ACX checker plug in and cannot for the life of me get it to appear as a new pluf=g in option. I have thoroughly read the chain from 2017 and am experiencing many of the same problems, but the solution does not work
1) When I search on my computer for a plug in folder, I get a folder that has nothing in it
2) I dragged the downloaded plug in into this folder but cannot get the .txt off of the end of the file name.
3) I have restarted everything again and again ... cannot figure this out.
Does anyone have any advice? I'm working on a MacBook and can't even seem to find anything but the actual application file for Audacity. I may sound pretty non-tech ... but I'm actually pretty good ... just not used to working with this equipment and have a three-books series waiting for me to get started.
Appreciate any help!!
Thanks!
Installing ACX Checker
billw58
Re: Installing ACX Checker
What version of Audacity?
If you have 2.3.2 or later (you really should have version 2.4.2) ...
Click on the Tools menu and select Nyquist Plug-in Installer .
Follow the instructions on the linked manual page.
After you have successfully installed it you'll need to enable it ...
Click on the Tools menu and select Add / Remove Plug-ins. Follow the instructions on the linked manual page to enable the ACX Check plug-in.
-- Bill
-- Bill
ACX Check appears under Analyze, not Effects.
Are you using Audiobook Mastering or some other pre-baked process for producing your work? It's almost impossible to announce directly into ACX Standard and the regular audio tools can drive you nuts.
