Hi
I am trying to hook my soundcraft USB desk to Audacity on my Macbook air.
I have sound going into the mac ok, and the soundcraft appears as an option on the input bar of Audacity but I cannot get sound into Audacity.
Please help.
Problems Getting Sound into Audacity
1967paulfoster
Re: Problems Getting Sound into Audacity
Does this fix it? viewtopic.php?f=47&t=103573
1967paulfoster
Hi
Unfortunately Audacity does not appear in that list.
billw58
This following might work.
Move the Audacity application to the Downloads folder. Start Audacity and attempt to record from the internal microphone. You should get a dialog asking for you to give permission to Audacity to use the microphone - do that. Stop recording and quit Audacity. Move Audacity back to the Applications folder. Start Audacity and attempt to record from the internal microphone.
-- Bill
-- Bill
