Audacity freezes when using space bar
Help for Audacity on macOS.
scy890
Re: Audacity freezes when using space bar
Post by scy890 » Mon Feb 15, 2021 4:41 pm
iMac - Catalina 10.15.7 - upgraded the RAM from 8GB to 16GB so would've hoped it would be able to keep up. Going to update to a newer version of Audacity. Wish me luck!
