No stereo recording
Help for Audacity on macOS.
[email protected]
No stereo recording
Post by [email protected] » Sun Feb 14, 2021 8:57 am
Hi,
I use mac Big Sur 11.2.1. I hav the latest version of Audacity 2.4.2.
I have checked all the possibilities there is for sound and recording on both my mac and audacity preferences, and I dont have the option of choosing stereo channel at all.
Can you please help me here?
Best regards, YPG
Re: No stereo recording
Post by steve » Sun Feb 14, 2021 10:14 am
Are you able to record in mono?
What are you trying to record, and what equipment are you using?
sensational fix
Post by sensational fix » Sun Apr 11, 2021 9:21 am
Same problem here. I don't have any option to switch to stereo, just the mono option.
My config is Deck (technics 1210) to mixer and from there to Audacity.
Can anyone help with this issue?
Cheers!
Post by steve » Mon Apr 12, 2021 7:17 am
If that is a USB / firewire or thunderbolt device, look in Finder: "Applications > Utilities > Audio MIDI setup".
In the "Input" tab, ensure that the technics 1210 is set to record stereo.
Then restart Audacity, and in the Device Toolbar, select the technics 1210 as the recording device and the number of recording channels to "2 channels (stereo)".
If it is not a USB / firewire or thunderbolt device, do the same for whatever device you are using to connect the deck to the computer.
sensational fix
Post by sensational fix » Wed Apr 14, 2021 7:13 am
I have to say that is not working. Both decks (also a digital controller) go through a Pioneer mixer that I use to record my radio show. Tried through both USB C ports and the microphone input, none of them can record on stereo in Audacity, i have no option to switch anywhere after rebooting computer and Audacity. Displayed just one option: "Mono 1 recording channel".
Is there anymore options to try to?
Thank you!
d.
Post by steve » Wed Apr 14, 2021 9:40 am
Was that in "Audio MIDI setup"?
sensational fix
Post by sensational fix » Thu Apr 15, 2021 9:35 am
No, that's in the Audacity toolbar. No other options to switch to stereo in any of the inputs :-/
Post by steve » Thu Apr 15, 2021 11:59 am
sensational fix
Post by sensational fix » Thu Apr 15, 2021 5:07 pm
Not an option in my computer. Attached a screenshot, sorry it's in Spanish.
Captura de pantalla 2021-04-15 a las 19.06.29.png (200.22 KiB) Viewed 295 times
Post by steve » Thu Apr 15, 2021 5:35 pm
What is the mixer? Is it one of these: https://www.aliexpress.com/item/4001226496694.html
